F250 Bed Rail Cap Removal and Aftermath - Ford Powerstroke Diesel Forum
post #1 of 6 Old 12-01-2013, 11:44 AM Thread Starter
FourthAxis's Avatar
Quoted: 2 Post(s)
During the second phase (rear 1/2) of bed-lining the exterior of my truck, I decided it was time to pull the bed rail caps.
We are bed-lining our ENTIRE truck, not just the bed. Since we're going to be using spray-on bed-liner (Monstaliner), the caps aren't important to protect against damage.
If you are just bed-lining the inside of the bed, I would NOT remove the caps. You will probably destroy them, and there are dozens of holes underneath them. I'll be filling mine somehow, because I'm a fool, but I've heard replacement caps are expensive.
Nevertheless, if you're dying to remove your plastic caps, there are clips underneath that can be squeezed with pliers to release them. HOWEVER, not all the clips can be accessed, so some require a bit of prying. If you pull directly on the plastic, it will fold over and break. If you pull too close to the clips, you may tear the clips right out of the caps (see photo). Lastly, if you yank too hard, you'll bend the sheet metal in the rails (see photo).
The best bet is a long pry bar that you can slide under the caps, and get close to the clips. Good luck, if you goof it up, you'll be left with this!
FourthAxis is offline
post #2 of 6 Old 12-04-2013, 12:37 PM
2000-7.3L's Avatar
Feedback Score: 10 reviews
damn, so looks like you have some bondo work ahead of you! Why are you lining the entire truck?
2000-7.3L is offline
post #3 of 6 Old 12-04-2013, 01:15 PM
schlutzer's Avatar
Quoted: 18 Post(s)
I've had mine off since I painted. I had minimal damage, I found once you got it started just wiggle side to side pretty hard and it would release the clips.
I did have to hammer down a few spots.
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
post #4 of 6 Old 12-04-2013, 03:17 PM
Quoted: 184 Post(s)
Feedback Score: 3 reviews
I changed mine when I bought my truck, wasn't hard and although I don't recall exactly what I paid for them (online dealership), I don't think they were expensive....
NoRalPh is offline
post #5 of 6 Old 12-04-2013, 03:30 PM
2000-7.3L's Avatar
Guys.... You know the diamond plate caps in the OBS trucks????????
Sent from AutoGuide.com App
post #6 of 6 Old 05-19-2014, 09:11 PM Thread Starter
FourthAxis's Avatar
Quoted: 2 Post(s)
Old thread, but I never saw a notification. I bed-lined the whole thing a few weeks ago, but it's white. I decided not to fill the caps, because they would need to be welded in. Bondo would have cracked apart if any stress was put on the rails. I just plati-diped the caps black, and threw them back on.
I looked for replacements, but didn't see anything I liked. Diamond plate is out because I don't have any chrome on my truck. I found clean looking black caps with no stake pockets for a long bed, but not the short. Oh well. On to bigger projects.
1999 CCSB, '05 front + axle, Monstalined exterior, shaved, tuned, lifted, 35s on 20s and blah blah blah
Our parts page: facebook.com/PowerstrokeParts
Email: Sebastian.Josh AT gmail.com
