Can i run 35s? - Ford Powerstroke Diesel Forum
post #1 of 2 Old 11-28-2013, 01:03 PM Thread Starter
kbragg430's Avatar
Can i run 35s?
I bought a new wheel and tire setup for my 2002 f350. The new super duty platinum wheels with the toyo open country a/t II in a 295/65R20. Which ar supposed to be just over 35" tall and about 11.5" wide. And i knowni need wheel spacers. Would i be able to run this setup with a fabtech 3.5 inch front hanger/shcakle lift kit without rubbing and leaving the rear stock? Or would i have to go taller? Anyone running this kit?
Thanks
Kevin
2002 F350 CCSB SRW 4X4 ~110k
4" MBRP, DIY Tymar, PHP hydra, Edge Insight CTS, 360* thrust, RR billet wheel, delete pedestal and outlet,
Napa ELC, melling 208 Lpop, 6.0 trans cooler, diy coolant filter, 203* thermostat, RR IC boots w/ plenum inserts, frx, hpx, hutch&harpoon
331 hp / 620 tq
Dynod by dynoproven 4/19/14
kbragg430 is offline
post #2 of 2 Old 11-29-2013, 08:25 PM
codyryan07's Avatar
Should fit just fine. You might have some minor rubbing on fender lining.. easy fix though, big zip ties and some tugging.
Cody Ryan
03 f250 ccsb fx4 7.3
4" RC lift
35x12.50 federals on 20x12 rockstars
6637 intake, straight pipe
full RR w/ fuel bowl delete.
rebuild coming soon
codyryan07 is offline
