New wheels and tire combo for 02 f250 - Ford Powerstroke Diesel Forum
post #1 of 12 Old 11-28-2013, 09:03 AM Thread Starter
bronco73's Avatar
Talking New wheels and tire combo for 02 f250
Hey guys, I have a 02 f250 extended cab long bed 4x4. It is stock ride height. I want to put on 18" wheels and tires. Looking to see what you guys have done and what size you have.
Thanks
bronco73 is offline
post #2 of 12 Old 12-06-2013, 07:41 PM
I put 18" wheels from a 2012 on my truck.
iowncars is offline
post #3 of 12 Old 12-12-2013, 09:38 AM
RioBoi28's Avatar
i got a two inch lift and level with 18's and 35 inch terra grapps very good not real high but deff planty more than stock hight
RioBoi28 is offline
post #4 of 12 Old 12-12-2013, 01:03 PM
Notalent's Avatar
Can you post pics? what kit did you go with? I have been searching around to do this same setup asap.
Beans
Magnaflow 4" Turbo Back
Riff Raff 6637 Intake
Edge CTS Monitoring System
Notalent is offline
post #5 of 12 Old 12-16-2013, 03:41 PM
027.3's Avatar
Not the greatest pic but here's my leveled (add a leaf) '02 with 33x13.50-18 terra grapplers.
'02 7.3 4 door 4X4 -- Leveled, WIcked wheel,4" turbo back w/ 5" tip, 6637, foil delete, zoodad mod, hutch/Harpoon mod, glow shift Egt & boost, 4- 7" 55w HIDs
027.3 is offline
post #6 of 12 Old 12-16-2013, 08:35 PM
RioBoi28's Avatar
fabtech is a real good one i went with and its affordable and let me see about being able to get a pic on here
RioBoi28 is offline
post #7 of 12 Old 12-16-2013, 09:00 PM
7.3pwrstrke's Avatar
This is without a rear block, leveling kit will be in this week to have it sittin how I want. These are 18" 07 rims with 2" wheel spacers
2003 F250 Lariat 7.3 160k
3" leveling kit, 22x14 Moto Metal 962, 33x12.50 Toyo MT, 2" wheel spacers
Harley heads, 08+ mirrors, 08+ taillights, LED switchbacks, HIDs, 20" LED light bar
DP Tuner, 4" turbo back (dumped before rear passenger tire), 6637 intake, Glowshift gauges
7.3pwrstrke is offline
post #8 of 12 Old 12-16-2013, 09:23 PM
RioBoi28's Avatar
stance.jpg[/IMG]"]http://[/URL]
RioBoi28 is offline
post #9 of 12 Old 12-18-2013, 06:53 PM Thread Starter
bronco73's Avatar
Hey Rio, what lift set up did you use. I would love to raise mine two inches but that is all. I work out of the back of my truck every day and at 5'-8" I am not real tall to put heavy tools in and out of my truck. That is why I bought a stock height truck. Others were just to tall.
Thanks
bronco73 is offline
post #10 of 12 Old 12-18-2013, 08:14 PM
RioBoi28's Avatar
in the back i have the 2" block and the level in the front with the lift i also took off the running boards to make it look taller but for only a 2" lift with 35"s I'm 6' and its actually a lil difficult at times to get up so its just up to you on the running boards ... Im getting the amp research steps put on so i can use them and then it still gives the effect of not having running boards when they tuck back up under the cab
i use the tailgate to work on all the time and i think its the perfect hight
RioBoi28 is offline
