| 99-03 7.3L Exterior Discussion Body and Accessories Talk |
Backspacing and offset question
I'm thinkin about gettin a new set of rims for my truck, but im not sure what offset and backspacing to get. I want the tires to sit under the truck as much as i can without serious rubbing, but i don't want it to look like a railroad truck either. Ive seen some trucks that have the almost the entire tire sticking out of the fender and it looks
![]() So if i go with a 9" wide rim, what is the offset and backspacing i need? What about a 10" wide rim. And can i fit 13.5" wide tires on a 9" rim? |
On a 99-04 4x4 you want to try and stick around 4.5" of Backspacing.
So, with a 9" wide wheel that's -12mm of offset and with a 10" wide wheel that's -25mm of offset. Yes, you can run 13.5" wides on a 9" wide wheel, 10" wide would be better. As for rubbing.....what size tires and what size lift are you running/going to run (I see your sig mentions a 6.5" lift in the future)? |
I plan on running 33 or 35 X 12.5 for now. The lift in stuff will be a while from now, like, at least a year. I plan on gettin a leveling kit untill then.
What would a -12mm offset on a 10" wide wheel end up like?
-12mm offset on a 10" wide wheel is 5" of Backspacing. Will sit a little further under the truck vs. the 4.5" B.S. and get the tire closer to the leaf spring during turning. With only a leveling kit on a 99-04 35/12.50s on 10" wides will most likely rub. You'd be better off sticking with a 33/12.50 |
PM me as soon as you can. Guess after seeing this thread, you are still thinking it over? Just let me know..................................
