Solution to bottom door rust? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 11-07-2013, 07:56 AM Thread Starter
Has anyone seen or used these yet? i found them last night. Im considering these rather than buying new doors for my 7.3
[IMG][/IMG]
kking08 is offline
post #2 of 5 Old 11-08-2013, 01:54 PM
I'm definitely curious how they work. Just bought a 99 out of Houston with some pretty rusted door bottoms. I wasn't going to bother with them but I'm curious how these work. Would you cut the lower portion of the door off and scab these on?
scottrepos is offline
post #3 of 5 Old 11-12-2013, 09:51 AM Thread Starter
I was thinking thats what would need to be done, im tryting to find out more.
kking08 is offline
post #4 of 5 Old 11-12-2013, 10:28 AM
MHCRRA16's Avatar
Running a body shop up here in Maine, we fix more rusty door bottoms than anything it seems. Yes, those patch panels are meant to replace the factory door bottoms after you have CUT the rusted sections out. Can be quite a job to weld in the new panels, but being able to buy the pre stamped pieces make life A LOT easier.
'06 F350 CCSB
Pro Comp 8" (maybe) Lift
20" Massey Hulk
37x12.5x20 Pro Comp Tires
A LOT of unknowns...work in progress...
Newly acquired...who knows what else has been done to this poor truck....
Stay tuned
MHCRRA16 is offline
post #5 of 5 Old 11-12-2013, 10:37 AM
Quoted: 780 Post(s)
If your doing the work yourself it will be cheaper. But if you have a shop do it, then you may be better off with new doors.
By the time a shop farts around with fitting, welding, sealing, bondo you'll have more labor($) in the job. Compared to new/good used door you just clean scuff up and paint.
Corey@CNCFAB is offline
