MonstaLiner bed liner install review - Ford Powerstroke Diesel Forum
post #1 of 11 Old 10-29-2013, 10:23 AM Thread Starter
Just rolled on a MonstaLiner bed liner kit into my 2001 Ford F250 Super Duty. Didn't find a whole lot of reviews of it online, so I took a chance on it. So far I'm very pleased with the ease it went on with and the look of it. I spent about 2.5 hours prepping the bed with sandpaper, cleaning it out, MEK and then drying it. I had to roll the liner on outside which wasn't recommended, but picked a day where the temp was about 50 degrees and sunny. First coat went on in about 45 minutes, and I figured it'd be a few hours before I could do the 2nd coat, however after about an hour, it was completely dry so I rolled on the 2nd coat. Started rolling on at 9am, and was done by lunch with both coats. I bought the 1 gallon kit, which did the entire bed, however if I were to do it over with again, I'd order an extra quart to do touch up with after the 2nd coat dried. I think the key to these roll on bed liners is to spend time on the prep to do it right, and roll it on slowly.
We'll see if it holds up over time, but its supposed to be UV protected so it shouldn't fade.
str8flexed is offline
post #2 of 11 Old 11-08-2013, 06:34 AM
Looks great! You picked a great product. I am planning on using it on both my F250 and my Land Cruiser. Here is some more reading about it from the Land Cruiser forum...
Monstaliner Bedliner
TX_TLC is offline
post #3 of 11 Old 11-08-2013, 06:59 AM Thread Starter
I would order the extra quart of roll on liner with the 1 gallon kit. There are some spots that I wish would have been thicker, and I wouldnt have to have been so concerned about spreading things out to cover it all. Other than that, I'm completely happy with it so far. I've not loaded anything in the bed since its been done, but plan to do so this weekend for sure with helping some friends move and going dirt biking with my son.
post #4 of 11 Old 02-21-2014, 09:58 AM
How has the Monstaliner held up the last couple of months? What have your temperatures been?
Semper Fi! FUBAR.
03SilverEx6.0 is offline
post #5 of 11 Old 02-21-2014, 10:08 AM Thread Starter
Held up great so far. We've had a terrible winter and it hasnt peeled or flaked at all. Havent had much in it other than dirt bikes so far though, although this spring I should have a few pallets of tile since we are redoing the sunroom.
2001 F250 Lariat 7.3L. 4" MBRP exhaust, 2" leveling kit, 35" tires, Diablo tuner
post #6 of 11 Old 02-21-2014, 12:10 PM
scagle1's Avatar
Derail for a fellow mudder , About to drop a 6.0 LS setup in the wife's 87 FJ , hopefully get a thread going over there as soon as I get the donor here.
OP , looks good , need to do the inside of my tailgate , will a Quart cover it ?
Sold 01 350 6" on 37's and mild mods, 00 X 4" on 35's, 02 f350 4" 35's modded from fan to drive shaft, ridin the 03 with nose conversion with 125k and counting upwards slowly.
Never had CNC's poo on any of it, never will.
scagle1 is offline
post #7 of 11 Old 02-21-2014, 05:06 PM Thread Starter
Quart should be plenty
post #8 of 11 Old 09-21-2014, 04:36 PM
biga**diesel's Avatar
Almost a year later how is that monstaliner holding up?
biga**diesel is offline
post #9 of 11 Old 09-21-2014, 06:37 PM
Vannnce's Avatar
Quoted: 13 Post(s)
whered you get it at?
-Vance-
.2002 f350 Lariat 4" lift w/ 35's. Hydra w/PHP. Swamps 175/146 injectors. gauges. banks power elbow, 4" dp 5"out,RiffRaffs FRX ww, ccv, AIH delete riff raff boost port, '10 tailgate mod amongst a bunch of other goods
.B&W turnover/ companion to haul my 2001 Prowler 5'ver. Home away from home
I.B.E.W. Local 1002
Vannnce is offline
post #10 of 11 Old 09-21-2014, 09:26 PM
StrokinAlaska's Avatar
Got me a longbed dually, how much should I get sir
05-07 Front
GlowShift Gauges
AFE C.A.I
4" d.p
TS-Performance 6 Position Chip
Wicked Wheel 2
Coolingmist Stage 1
14lbs Nitrous Oxide
(2) 52" VisionX Xmitter Led bars
VisionX Cannon 4.7"
VisionX Cannon 6.7"
(2) 42" RaceSport Led bar
(4) VisionX Solo Soltice
(4) RaceSport Duallys
Hids
Alpine INE-S920HD
20 Speaker Rockford Fosgate Stereo System
3 Bulk Packs of Ballistic
Smoked Cab Lights, Fender Lights, SwitchBack Leds
Tint
2.8" Front leveling kit
StrokinAlaska is offline
