Help me Buy Wheels: 00' CCLB 2.5 Lift - Ford Powerstroke Diesel Forum
post #1 of 23 Old 07-23-2008, 08:09 PM Thread Starter
AFBLUE's Avatar
So my original plan was to get my stock 16s coated black, but then I did some looking and found that the 315/75/16s Nitto Terra Grapplers can't mount on that narrow of a rim.
So my options have opened up now since Ideally I would need to get at least 16X8.5s. But now that I am going with new wheels, I would entertain going to 18s (17 seems odd to find decent tire prices) But the key is I want Black wheels!!! I am trying to black out the truck but I would go with chrome accents like bolt studs, but I know 2 tone wheels will not last in New York when I finally leave TX. one winter and anything not painted with corrode.
So from experience what sizes am I able to fit on a 00' CCLB 4X4 I know 315/75/16 would fit, but what about width and offset for wheels then what tire size to match it.
I am looking for is to be $200 or less for the wheel and 250 or less for the tire. Aggressive All Terrain/Mild mud IE No Nitto Mudders.
06 CCSB Lariat 102K
Factory 20s w/ Nitto Trail Grappler 35X12.5X20
Vegistroke 75,000 miles
2.5" Readylift Level
ARP Head Studs
EGR delete
Swamps 58V FICM
Isspro Gauges, EGT, Boost, Trans.
20ft of 4" straight pipe!!
SCT X3 BAMF Innovative Xtreme Race
AFBLUE is offline
post #2 of 23 Old 07-23-2008, 08:16 PM
duct tape & zip ties
bigcountrysg's Avatar
315/75R16's can be mounted on stock rims. I see it all the time. If a shop said it can't be done. Go to a different shop.
But if you want new rims I would stick with the 16 inch rim. Get either Mickey Thompson Baja Claw, Toyo Open Country, Pro Comp Extreme AT, I mean there is endless options with 16 inch rims. If you want wider rims then go with a 16x10 inch rim. backspace I would have it so it works out to be about the same as the stock back spacing.
Your Actions Today, Decide Your Future Tomorrow
2005 6.0 Crew Cab Long Box Lariat, current truck
2004 6.0 destroyed by contaminated fuel
2002 7.3L burnt
bigcountrysg is offline
post #3 of 23 Old 07-23-2008, 08:25 PM Thread Starter
AFBLUE's Avatar
I am sure they can get put on my stockers, and I have seen it too, just didnt know how good it is for the tires life, load capacity and wear. What are the stock wheel size? I thought I read they are 16X7?
06 CCSB Lariat 102K
ARP Head Studs
EGR delete
Swamps 58V FICM
AFBLUE is offline
post #4 of 23 Old 07-23-2008, 08:28 PM
Baller1771's Avatar
Send a message via AIM to Baller1771
i have KMC XD Enduros black for sale if you want. there same size as stock 16" $400
Dillon- ILLIANA art director
Click to hear 03 Turbo whine Straight pipe
Baller1771 is offline
post #5 of 23 Old 07-23-2008, 08:31 PM Thread Starter
AFBLUE's Avatar
so you are talking 16X7s then? If I am going to buy wheels I would like bigger or wider than stock, or I might as well coat my stockers for $200.
06 CCSB Lariat 102K
ARP Head Studs
EGR delete
Swamps 58V FICM
AFBLUE is offline
post #6 of 23 Old 07-23-2008, 11:29 PM
I have never seen a rim size 16x7. Now I have not measured my stock rim size but I bet it is 16x8 which is a very common rim size.
2002 7.3L burnt
post #7 of 23 Old 07-23-2008, 11:32 PM
KYStrokin's Avatar
i have 315/75/16 on stockers on my hunting rig. They fit, but do not hold a bead as well as an 8 to 10 inch wheel would. They sink into the wheel.
KYStrokin is offline
post #8 of 23 Old 07-23-2008, 11:35 PM
Well after some research the stock rim does measure 16x7. But that just don't seem right. It sure does not look like a 7 inch wide rim.
I would say screw metric size and get a 35x11.50R16 and be done with it.
2002 7.3L burnt
post #9 of 23 Old 07-24-2008, 12:49 PM
Dave,
Get 16x10. With typical 315/75/16 you might rub the leafs. I have 16x10 and 35 BFGs and they dont rub the leafs but they rub the fender lining when the tires are new. Since the tires are half worn, they dont rub anymore. 16x10s will stick out more and I like that look better than tucked in wheels.
2003 7.3L
DP Tuner
9.5" lift
37" Toyos
JW Trans
Vegistrokin
optx002 is offline
post #10 of 23 Old 07-24-2008, 08:40 PM
Some pics of how my wheels and tires look on my truck. Im planning on powdercoating then flat black eventually.
2003 7.3L
DP Tuner
9.5" lift
37" Toyos
JW Trans
Vegistrokin
optx002 is offline
