4" all spring lift??? - Ford Powerstroke Diesel Forum
post #1 of 8 Old 10-19-2013, 08:18 AM Thread Starter
Quoted: 2 Post(s)
Hi all - I'm looking to put a 4" lift on my truck but I'd prefer an all spring system rather than blocks. I've been looking at a BDS or ICON but again all I've found are kits with front springs and rear blocks. I am wanting a quality sysem that still can handle heavy loads. Does anyone have ideas or suggestions?
Sent from my life controlling phone!
doug_oman is offline
post #2 of 8 Old 10-20-2013, 03:39 PM
Skyjacker has a all spring 4" lift, its expensive but their just about the best in the business
marylandstroker is offline
post #3 of 8 Old 10-24-2013, 09:19 AM
CSIPSD's Avatar
I prefer to keep the factory springs on a 4-6" lift. It allows you to keep the factory overloads, air bags are easier to install and the spring quality is generally better then the aftermarket...
There is no issues with blocks, so long as your not stacking them. I just replaced my blocks a few month ago with these...
Ford Fabricated Lift Blocks
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #4 of 8 Old 10-24-2013, 06:04 PM
Did you use the lift blocks front and rear?
2003 F250 Super Crew - Sinister EGR Delete, ARP Studs, Blue Spring, FICM by Ed, Atlas 40, Pioneer Double-Din
1999 Dodge Dakota Sport 4x4 - Show Truck
2005 Scion XB - DD
jimdman is offline
post #5 of 8 Old 10-24-2013, 06:59 PM
Macon's Avatar
You never use blocks in the front. Never ever.
2002 F250 CCSB 4x4
PHP Phoenix, John Woods VB, NUC bypass, 6637
"No country can be called free which is governed by an absolute power;
and it matters not whether it be an absolute royal power or an absolute
legislative power, as the consequences will be the same to the people."
--Thomas Paine, Four Letters on Interesting Subjects, 1776
Macon is offline
post #6 of 8 Old 10-24-2013, 08:56 PM
SUPERDUALLY350's Avatar
i have a block in the rear and put a 4 inch bds spring in the front rides like a dream. when i bought it it had a 3.5 inch lift but they stacked the springs on the front so it rode like ****. its has a pretty level stants
ID:	186633   Click image for larger version
SUPERDUALLY350 is offline
post #7 of 8 Old 10-25-2013, 03:04 AM
I used the icon 4" lift. Better ride then stock and retains payload and towing capacities. It gives you the option of leaving your factory blocks in the back or removing them. If you leave them in your truck will still have the stock rake with the front sitting about an inch and a half lower than the front. Kit came with everything you need for install including a track bar drop bracket and a drop pitman arm.
2000 F250 CCSB 7.3 PSD 6 Speed CFM Intake Manifold AFM Stage 2 Intake Snow Performance Water/Methanol Injection 160/100 Injectors GTP38R Adrenaline HPOP 203* Thermostat Air Dog II Gear Vendors Over/Underddrive 450HP Clutch 4.88 Gears ARB Lockers Mishimoto Intercooler Turbomaster Wastegate Controller 4" Turbo Back Exhaust DP Tuner Icon 4" Lift 37" Procomp Mud Terrains Fabtech Tration Bars
wallace2000 is offline
post #8 of 8 Old 10-25-2013, 10:36 AM
CSIPSD's Avatar
Hummmm...
NO!
Spring fronts and a single 5.5" block in the back. With a 2" add a Leaf for the load capacity I need (Truck weighs 8800+ pounds just driving down the road)...
Joe
CSIPSD is offline
