Driver's door won't latch - bounces open - Ford Powerstroke Diesel Forum
post #1 of 13 Old 07-14-2008, 09:05 AM Thread Starter
Danbeck's Avatar
I haven't been able to find a post that answers my door situation. The driver's door won't latch easily - it will eventually latch about one out of 50 tries, but the other 49 it just bounces open. The actual latch on the door will not click/snap closed with a screwdriver like all the other doors. Perhaps there's a broken spring or loose screw? When the door does latch, the interior/exterior lights go out as usual. Any help is appreciated... Dan
Danbeck is offline
post #2 of 13 Old 07-14-2008, 03:48 PM
layson's Avatar
Quoted: 82 Post(s)
Have you tried taking the door apart and greasing up the latch? It may help?
2001 - 14" OUO 525 - 38x15.5x20 Toyo & 20x12 Weld Cheyenne's. Hybrids, 38R, BTS, Spearco, Terminators..
Quote of the Day:
Originally Posted by Mannysouza View Post
You will get some axle wrap with a heavy trailer, I can feel it when towing my gooseneck with some heavy equipment. My Deavers will wrap enough to make the tires rub the front of the rear fender well if I give it too much throttle on aceleration.
layson is offline
post #3 of 13 Old 07-14-2008, 03:56 PM
sawyer1's Avatar
Have you tried wd-40 maybe itll losen it up
-Sawyer-
USAF COP!!
2000 F-250 Lariat, 142,000mi automatic trans.
SOLD SOLD
New rig 2006 dodge cummins mega cab
sawyer1 is offline
post #4 of 13 Old 07-14-2008, 04:53 PM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
Look at the latch in the door and see if is closed. Sometimes it happens. If that is the case, take a screwdriver and stick inside the latch, pull the handle and then pull the latch open.
Latch may look like this.
Should look like this.
dhanna6powerstroke is offline
post #5 of 13 Old 07-14-2008, 04:56 PM
Mod Newbie
Quoted: 20 Post(s)
I'm an idiot. Didn't read your post all the way or read it wrong. Just disregard my post and laugh at me.
post #6 of 13 Old 07-14-2008, 05:09 PM
Other vehicle is an F250
Hank's Avatar
I thot you did a real good job! You went to a lot of trouble too! That's what this site is all about. I'm not laughing. Thanks for trying to help him!
2001 F250 Lariat Crewcab, Automatic, 4X4
(Late '99 Regular Cab Work Truck)
6.5" Pro Comp Lift ~ Traction Bars ~ Son-Built Sliders ~ 16" Pro Comp Xtreme Wheels with 35" BFG TA KM2s
4" Banks Exh.-Power Elbow ~ Wicked Wheel ~ DIY AMSOIL EaAU4090 Intake ~ PHP 6 Pos Chip ~ LowDown LED Upgrade
Stage 1 Injectors ~ HankDaddy
Mod. ~ BUILT TRANNY! 352 HP Shootin' for 375!
CAROLINA POWERSTROKE ASSOCIATION
Hank is offline
post #7 of 13 Old 07-14-2008, 05:23 PM
Mod Newbie
Quoted: 20 Post(s)
This is the greatest site ever. You all have helped me before and I like to try and return the favor if I can.
post #8 of 13 Old 07-14-2008, 06:34 PM Thread Starter
Danbeck's Avatar
Thanks for the help friends! I ended up trying what was suggested for doors that don't LOCK, and doors that make the AJAR light stay on, etc. I cleaned the visible parts of latch with brake fluid as suggested on this site, and then drowned the latch with silicone spray. Within two slams of the door (light, careful slams....) it latched and kept latching. I oilspray my vehicles twice per year due to the extremely high amount of winter salt usage on these Vermont roads. I think the blend of bar & chain oil and ATF was gumming up these latches. All's well here now... Thanks again!
Danbeck is offline
post #9 of 13 Old 07-15-2008, 03:51 PM Thread Starter
Danbeck's Avatar
Well it didn't take long to start acting up again. Same deal. I've drowned the latch several times with silicone - won't engage and stay shut. Any ideas anyone? Something broken? It will eventually latch about every 50th slam shut.... Dan
Danbeck is offline
post #10 of 13 Old 07-15-2008, 04:54 PM
layson's Avatar
Quoted: 82 Post(s)
I would get a new one! Once you get the door panel apart and remove the plastic door handle the latch may be easily reached. Just unbolt it and replace it with another. There may be a better one in the junkyard? Maybe you could clean it better? Maybe the latch needs to be adjusted some?
Or you might beable to clean it out better with the door panel apart?
They are real easy to take off ...
Quote of the Day:
layson is offline
