99.5 f350 to 2006 excursion mirror swap - Ford Powerstroke Diesel Forum
post #1 of 2 Old 10-13-2013, 09:14 AM Thread Starter
needinajeep's Avatar
I have 1999.5 F350 dually CC and my brother has a 2006 Excursion. He is upgrading his mirrors so I wanted to put his mirror on my truck. Problem is he has the flat gray seven pin connector while I have a white circle three pin connector.
I know I can wire the turn signals for the signal lights under the dash but need to be able to wire my mirrors to work on his truck till he gets his 2011 mirrors in and wired up.
Does anyone have a wiring diagram for the gray seven pin connector and the white circle three wire plug?
I can use three jumper wires to work on his truck till we install the newer ones.
1999.5 F350 CC LB 2WD DRW- Tow Rig, 4" Stainless Turbo-Back Magnaflow Exhaust, 6.0L Trans. Cooler, Foil MOD, CCV Mod, 05-07 Harley Headlights & Badges, AMSOIL DIY Intake, ATS Ported Turbo Housing, Gauges - CS Insight, HPX, Mag-Hytec Trans & Diff Cover, BTS V/B. I have a fass fuel system and regulated return w bowl delete waiting to be put in.
needinajeep is offline
post #2 of 2 Old 10-14-2013, 07:32 AM Thread Starter
Nevermind got it taken care of
