Headlight Problem!! - Ford Powerstroke Diesel Forum
post #1 of 3 Old 09-28-2013, 05:26 PM Thread Starter
Majer93's Avatar
Exclamation Headlight Problem!!
I have a 2000 F-250 that I bought used. I put in aftermarket headlights about a year ago and now all of a sudden they do not work. The turn signals and halos work but the actual bulb will not light. I have replaced them both, but still no luck. Any ideas? Thank you for the help in advance!
Majer93 is offline
post #2 of 3 Old 09-29-2013, 01:35 AM
JSchuricht's Avatar
Check your fuses then check the switch.
JSchuricht is offline
post #3 of 3 Old 09-29-2013, 04:13 PM Thread Starter
Majer93's Avatar
Fuses are all good. What do you suggest I do to test the switch?
Majer93 is offline
Tags
2000 , electronics , f-250 , headlights , power
