Need advise on level kit Rough Country - Ford Powerstroke Diesel Forum
post #1 of 9 Old 09-23-2013, 12:54 PM Thread Starter
sleekvino's Avatar
Hello,
Looking to see if anyone has or had rough country's level on their trucks. Shopping around this looks like a pretty good deal. Looking to get my 250 to sit level.
2.5in Leveling Lift Kit (Springs) for 99-04 Ford 4wd F-250 / F-350 Super Duty | Rough Country Suspension Systems
Any input is appreciated. If you don't like this kit, could you recommend one that is better?
Thanks in advance.
VC
BPD FICM
SINISTER COOLANT FILTER
33"
bluespring upgrade
Airaide coolair intake
Kenwood DDX470
Gutted Cat
leveling kit 2.5" ROUGH COUNTRY
10" kicker sub
800w MTX 5 channel amp
SCT x 4 with Looney tunes
remote starter
2 Doberman pinschers on guard!!
on the list
straight pipe
Federal Ownership Respectfully Declined
sleekvino is offline
post #2 of 9 Old 09-23-2013, 12:56 PM
Raul@Stealth Automotive's Avatar
thats a good kit.... you can also do something like this http://stealth-automotive.com/index....roduct_id=1019
Raul@Stealth Automotive is offline
post #3 of 9 Old 09-23-2013, 01:11 PM Thread Starter
sleekvino's Avatar
Sorry man put this in the wrong section. I have an '04 6 liter. Would those shackles work for an 04??
BPD FICM
33"
bluespring upgrade
Kenwood DDX470
Gutted Cat
10" kicker sub
remote starter
on the list
straight pipe
post #4 of 9 Old 09-23-2013, 02:08 PM
yup...........
post #5 of 9 Old 03-20-2014, 08:26 AM
SJB
SJB's Avatar
Quoted: 2 Post(s)
Does anybody that has dealt with this kit know if it does indeed lift just 2.5"? I read a lot of comments about adding new springs often result in higher lift than advertised.
2002 F250 XLT CC 4x4
- Isspro EV gauges (Pyro, Trans temp, Boost)
- Walker BTM Muffler
- 6.0 Liter Transmission Cooler
- '08 Kool-Vue tow mirrors
- Tuff Country 2.5" leveling kit 22962KN
- Factory F350 blocks in the rear
- Readylift 67-2094UB u-bolt kit for the rear
- Moto Metal 970 18x10's w/ -24 offset
- Cooper Discoverer S/T Maxx 295/70-18's
SJB is offline
post #6 of 9 Old 03-20-2014, 08:53 AM
7.3pwrstrke's Avatar
Yeah, you're going to get more than 2.5" from where you sit right now. Stock leaf springs are usually pretty worn out from time so it's hard to tell how far they've sagged down. I usually run leaf packs because you can more easily decide how much lift to get.
Something like this. eBay has a ton for really cheap. It's basically 1/2" steel plates. So 4 plates = 2" of lift, 5 plates = 2.5" of lift etc
2003 F250 Lariat 7.3 160k
3" leveling kit, 22x14 Moto Metal 962, 33x12.50 Toyo MT, 2" wheel spacers
Harley heads, 08+ mirrors, 08+ taillights, LED switchbacks, HIDs, 20" LED light bar
DP Tuner, 4" turbo back (dumped before rear passenger tire), 6637 intake, Glowshift gauges
7.3pwrstrke is offline
post #7 of 9 Old 03-20-2014, 12:45 PM
SJB
SJB's Avatar
Quoted: 2 Post(s)
Thanks for the info. I actually wouldn't mind if the spring kits lifted a little more than the 2.5", but I just wanted to be prepared for it in case it lifted so much that I need to add other parts to make sure all geometry's are correct.
SJB is offline
post #8 of 9 Old 03-20-2014, 01:17 PM
Yeah, I'd get a zone offroad adjustable track bar. Stock pitman arm should be fine.
post #9 of 9 Old 03-20-2014, 02:21 PM
SJB
SJB's Avatar
Quoted: 2 Post(s)
I was looking at that Zone track bar. Looks like a good, affordable option. I was looking at possibly piecing a lift kit together (as in some cases it looks like I could do it for more affordable than some of the prefabbed kits). But when looking at spring packs, I wasn't sure whether I should order the 2.5" spring packs or the 4" spring pack to achieve roughly a 4 inch lift overall. Not sure if the 2.5" would give me close to 4" in the end, and whether I'd end of getting closer to 6" with the 4 inch springs.....
SJB is offline
Tags
leveling f250
