RECON headlights - Ford Powerstroke Diesel Forum
post #1 of 10 Old 09-14-2013, 12:26 PM Thread Starter
RECON headlights
Just finished the install of my headlights and I wasn’t too happy about the fact I had to cut the header panel……but they look great, now for the issue. I have a shadow beam across the light beam??????????????? At first I thought it might be my bug shield so I opened the hood but nope, so any ideas on what this is? Or is this just a result of the lights design?
fomoco is offline
post #2 of 10 Old 09-14-2013, 12:37 PM
ZMANN's Avatar
Quoted: 1670 Post(s)
Recon does a great job of looking great
We Miss you Ronnie
ZMANN is offline
post #3 of 10 Old 09-14-2013, 12:43 PM
DunesRunner08's Avatar
Which model did you use? and the only way you would have to cut the header panel is if you used the 05-07 lights... as for the "shadow beam" post a pic and I can try and help you diagnose that
Beware!!!! The King Has Returned
DunesRunner08 is offline
post #4 of 10 Old 09-14-2013, 02:33 PM Thread Starter
I called them direct and there answer was because I have an 2002 four door and on there web sight they have the directions on where to make the cuts(check it out if anybody is looking to do this) didn't sound right to me and I asked about returning them and was given a BIG FAT NO! I have had them to long?????? it took me a few to get around to the install. I will try and see if I can get a pic.
fomoco is offline
post #5 of 10 Old 09-15-2013, 10:33 AM
Powerstroke Junkie
NCHornet's Avatar
Cutting the header is needed when using any of the 2005 and newer lights, either that or use a newer header panel as well. I know you don't want to hear this but I have been reading a lot about Recon being nothing more than a relabeler of the made in China cheap headlights that are sold on Ebay for 1/3 the price. They aren't close, they are the same exact light. If I were you I would start with sealing the lights to prevent any moisture issues, either with a plastic welder and a good silicone. Are you running HID's because HID's are suppose to use a different reflector.
NCH
Proud Father of USAF Airman
2000 F350 DRW,CC,LB, 4X4, Western Hauler Pkg.
Ford AIS/ BTM, FTVB
My CCV MOD, Coolant filter
06 Grill, 05 lights,6.0 trans cooler
Cyro/Hawks, JVC Touchscreen HU, JL C5's, Infinity 800watt amp,
DP tunes, 60 tow/80 e/120 race, on a SCT2 tuner
P3 controller, Brite Box Turbo Lifesaver
KMC Wheels x 4
Friends Don't Let Friends Drive Trucks With Generic Tunes
NCHornet is offline
post #6 of 10 Old 09-16-2013, 05:14 AM Thread Starter
ATTN: Ford Superduty 99-04 Crew Cab Owners:
You will need to make a few simple modifications to the mounting area of your 99-04 Ford
Superduty truck only if you have a ”Crew Cab” body style. The modifications are simple and
straight forward…basically you must cut away some of the body behind the headlight where we
have clearly marked with black x’s on all the images located below: Im not sure about the 05 or new lights but this info is from there web sight, I don't think it would matter what lights you use you still will need to cut the header. But thanks for the info on sealing the lights as for the bulb im just using the bulb the headlights came with.
fomoco is offline
post #7 of 10 Old 09-16-2013, 08:32 PM
Yeah it's a Turbo Diesel
mts678's Avatar
Quoted: 12 Post(s)
Feedback Score: 12 reviews
well HID's don't use a reflector at all, they're designed to be utilized in a hid projector, see the link in my sig for how to do a retrofit. I just sold my 6.4 and one of the first things on my list is to do the 05 headlights and a hid retrofit on those. 2 years ago I had a 05 and was 3/4 of the way done with the retrofit when the truck was stolen. So i bought a 6.4 and did the retrofit on it. Best headlights PERIOD! Don't run the cheap chit hid kit in your stock reflectors, you'll just be disappointed again. Retrofit is the best way.
2017 f250 platinum
Bone stock until warranty expires!
mts678 is offline
post #8 of 10 Old 09-25-2013, 05:17 PM
7 3 Powerstroke's Avatar
Speaking of HIDs. I need some help. I love my headlights, but I have/want to run HIDs, and my headlights are designed for normal bulbs. I'm still trying to decide if I should get projectors because I'm not a huge fan of the bubbled out parts. What do you guys think of these?
The only things that they have over my headlights is that I love the halos, and I can run my HIDs without scattered light.
2001 7.3L F350 Crew Cab, Long Bed, Dually.
Modifications: aFe Stage 2 CAI, 4" Flowmaster Exhaust with 7" Tip, XDP Compressor Wheel, Foil Delete, Glowshift MaxTow Gauges (Boost, EGT, and Pyro), and Tony Wildman 6 Position Chip.
7 3 Powerstroke is offline
post #9 of 10 Old 09-25-2013, 06:30 PM
mts678's Avatar
Quoted: 12 Post(s)
Those have halogen projectors. The light output is poor quality on those lights. If you want a true hid set up that compares to the luxury cars hids, then do it as I described above. You'll never have halogens again after you have these. Look up my threads in the 6.4 electronics section. 2008 psd hid projector retrofit
2017 f250 platinum
mts678 is offline
post #10 of 10 Old 09-25-2013, 07:18 PM
It says they are HID projectors, and it comes with most of the HID kit pre-installed. And I'm not looking to do that much work really.
