F#$%%#%@## frozen caliper slide pin - Ford Powerstroke Diesel Forum
post #1 of 22 Old 09-04-2013, 12:41 PM Thread Starter
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
I am replacing the caliper pins on my SD and for the life of me i cannot get it out, i tried a wrench on it, then i stacked washers on the bolt that goes into it and went to town with a breaker bar...snapped the threads right off. soaked it in WD-40. I heated it up with a butane torch and still wont let go. I dont have access to an oxy-acetylene other wise id use that but short of that or completely drilling it out i dont know what else to do.
To give you an idea of how stuck it is, i could see the bracket flexing as i was torquing on it Any ideas how to get it out?
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #2 of 22 Old 09-04-2013, 02:22 PM
Macon's Avatar
Drill out the center to give it some relief, like you would for an ez-out. Sucks to hear you're having such an issue.
2002 F250 CCSB 4x4
PHP Phoenix, John Woods VB, NUC bypass, 6637
"No country can be called free which is governed by an absolute power;
and it matters not whether it be an absolute royal power or an absolute
legislative power, as the consequences will be the same to the people."
--Thomas Paine, Four Letters on Interesting Subjects, 1776
Macon is offline
post #3 of 22 Old 09-04-2013, 03:05 PM
Quoted: 902 Post(s)
Feedback Score: 3 reviews
Hey Pat, were you able to get the old bolt out? If so get some Loctite bolt freeze. That stuff is the cats arse. Spray that down the threads then put a longer bolt in and tap it out.
Corey@CNCFAB is offline
post #4 of 22 Old 09-04-2013, 04:29 PM Thread Starter
Chapter Director
Quoted: 5 Post(s)
Im really not looking forward to drilling it only because i know thats some tough metal if not grade 8
No unfortunately it busted about 1/8th of an inch down. What would a longer bolt do? I can get a pair if vice grips on it and can put my full weight on it and it wont even budge. Im gonna take it to work tomorrow and put it in a big arse vice and try to get it that way
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #5 of 22 Old 09-04-2013, 04:31 PM
schlutzer's Avatar
Quoted: 18 Post(s)
mine was stuck so bad I welded a pair of vise grips to it and between heat, penetrating oil, more heat, more oil, and 2 days I was able to get it free. I don't really think there is an easy way, just a lot of time or replace the bracket if it's just not going to come out.
If you do get it out, clean out the hole. I used a wire wheel on a dremel and then clean it at work, You want it as clean as possible before installing a new pin.
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
post #6 of 22 Old 09-04-2013, 04:33 PM
Macon's Avatar
If they have a drill press at work, that would save a lot of cussing...
2002 F250 CCSB 4x4
Macon is offline
post #7 of 22 Old 09-04-2013, 04:51 PM Thread Starter
Chapter Director
Quoted: 5 Post(s)
Yea im gonna clean it real good if i get it out and i got the new updated slider pins that supposedly dont corrode as bad...supposedly
Hmm ill have to see i dont work in the shop so i cant remember if ive seen one or not
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #8 of 22 Old 09-04-2013, 05:02 PM
2000-7.3L's Avatar
Feedback Score: 10 reviews
If you don't get it out, you may need to go to the bone yard and get a new bracket!
2000-7.3L is offline
post #9 of 22 Old 09-04-2013, 05:02 PM
Quoted: 902 Post(s)
Thread a longer bolt in it, then put a pair of vise grips on the bolt below the head of the bolt then use a hammer to smack the vise grips kind of creating a slide hammer effect. I've used the loctite freeze at work and it really does do a better job than a torch. We used it last on a 2" diameter bolt that wouldn't budge with a torch.
post #10 of 22 Old 09-04-2013, 05:04 PM
Heat and beat. Worse case they are not too bad expensive at auto parts stores. Every store I called had them in stock. LOL
2006 Ford Powerstroke Super Cab 4x4 auto 120K bulletproofed
ramz trk is offline
