Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Exterior Discussion
Old 10-21-2006, 03:14 PM
racerjacer racerjacer is offline
Any advice on how to remove tow mirrors??
Just a shadetree mechanic wondering how the heck to get a retractable tow mirror off. I have removed all I think I can but it is being stubborn. I would shure appriciate some advice. Thank you kindly for your time.
Old 10-23-2006, 03:54 AM
dog3434 dog3434 is offline
Just going by my memory, I'm no where near my truck, you have to remove the cover on the inside and then remove the two decals that cover the holes. I think there are 4 nuts but I could be wrong. Use a small racket with a 10mm or an 8mm socket. Use lub in the socket to keep the nuts from falling into the doors. Once all of the nuts are off the mirror will fall off the truck. You will have to disconnect the cables but I can't help there. If you can't get the mirror loose then you missed a nut.
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
