thanks to Joel from this forum I now have a kargo master over canopy rack on my truck and i'm thinking about possibly getting a rzr. kargo master says that the rack is rated for 1700lbs and it looks like a rzr is about 1000lbs.
has anyone seen anyone haul a rzr or even a quad or two on one of these? i'd like to be able to do this so I still haul a regular travel trailer around instead of picking up a toy hauler big enough to haul a rzr in the back.
are the bedsides of the truck strong enough for this?
If you have a long bed (link says long bed) why can't you just put the rzr in the bed?
I have seen some crazy loads in the past, but never a UTV completely above the cab of a truck. So I am subscribed to see what other members have to say.
i'd like to put it on top so I still have the full bed with canopy for dogs and other camping stuff while still pulling a travel trailer behind.
it's a little less than 7' right now to the top of the rack and a rzr is just under 6' tall to the top of the cage so it would be about be at about 13' tall. I figure by the time the rzr and trailer are hooked the suspension will drop at least 2 or 3 inches.
i'm not really worried about the height, more the strength of the rack and truck box.
I think setting 1,000lbs up that high is just asking for trouble. Its going to make the truck very top heavy. I Have a rack that slides into the bed of my truck and I carry 2 ATV's side by side and tow a camper. I dont think I would want to place these more than maybe 6 inches higher. I have taken turns where I could feel the truck start to really shift with the weight above the bed rails.
I would recommend looking into a rack like I have. I know there are a few company's out there that make these racks for RZR's and other side by sides.
Here is a website for ya. UTV Transport
Here is what my rack looks like loaded
Hope all this helps and let us know what you end up doing.
an 11.5' camper weighs 4000lbs+ dry/unloaded with most of the weight somewhere around the top of the cab so 1000lbs at the top of the cab doesn't seem unreasonable. i'll probably need to put in a set of airbags to stiffen it up.
loading and unloading would be done with a couple of 14-16' aluminum ramps and probably use the winch on the rzr to pull itself up for safety.
If I were you I would just run a sled deck like MuddyAtv's and you would have room for stuff underneath the deck and still be able to tow your trailer. I wouldn't want an rzr over my cab personally especially if you'll be almost 13' tall.
Youre begging for police attention with a setup like that. Id have to check the books for technicalities but if I saw that myself, I'd have to pull you off the road anyway for an unsafe/dangerous load. It's not a matter of writing any citations and making anybody's life difficult but I couldn't witness a load like that and feel morally okay with letting it travel. Things may be different in Canada.
I've got 2 big dogs to haul around with me when we go camping so I kind of need the canopy.
13'6" is legal height without a permit. I figure it's going to be closer to 12'6" by the time it's all loaded up and on the truck anyway. i'll probably build the deck with divots for the tires to drop down into a few inches.
my biggest worry is the strength of the bed sides. the rack itself is rated for 1700lbs but how much can the bedsides handle before they start spreading?
Depends on where you're anchoring the camper and how tall it is but a rzr on a ladder rack? No. Don't get me wrong or anything-- I'm not trying to be a prick. I'm trying to save you from unwanted trouble. Do I personally think it'd work? It's hard to say but doubtful. I'd severely question its structural integrity and drivability on anything but a long, straight, level road.
Just because you can, doesn't mean you should. If you get in any sort of accident (regardless of fault), you will be found liable for your unsafe/dangerous load.
Sounds like a terrible idea. My truck sways enough going across uneven lanes in some of the construction sites around here, can't imagine how it would feed with 1000lbs over the cab of the truck.
dont do it. that is way to high for a rzr.
I know a guy that had the set up that muddyatv24 post for this rhino. he loaded it once and never did it again. putting over 1200lbs that high will cause to many handling issues.
you said the reason for this is because the dogs, can't put the dogs in the camper?
I got suckered into helping my father in law move some old lumber yesterday and ended up with about 1500 lbs (I think closer to 1800 lbs) of old rough cut 2x10's on the rack (22' lengths). it didn't feel like much.
I also had about 600 lbs in bed. I think it will be ok as long as I make sure there is some weight in back down low.... like a travel trailer attached to the rear.
I've driven trucks with campers many times over the years and my daily driver is a Mercedes sprinter high roof with about 200 lbs worth of roof and rack on top (10'6" tall). i'm used to driving with a lot of rocking and swaying so stuff like changing lanes on a rutted highway in high winds doesn't phase me anymore.
by law you're not supposed to have pets or people ride in trailers while being towed and I get the feeling that riding in a trailer down the highway isn't comfortable either
so in a nut shell, it's probably going to happen... just need to buy a rzr now. i'll even post the pictures on pirate. it will be funny to watch the sheep jump on the bandwagon.
Mmk. Just pray for an uneventful trip. Just remember: You're liable. If you so much as fart the wrong way while driving and something happens, expect full repercussions. :senile:
It was mentioned in an earlier post, but I would look into DOT regs concerning maximum height of a passenger vehicle. just something to think about. But good luck. And post a picture on here too if you don't mind.
A UTV on a ladder rack :crazy: I can't wait to see this... I wouldn't want to be behind the wheel with 75-100% of my cargo capacity 6 feet above the bed, not to mention cargo with its own suspension swaying around!. WOW!
DON'T FORGET TO TAKE PICS BEFORE AND AFTER
The guy is asking for trouble..... Any strong side winds, and he'd be white knuckling it, if he could. Hope his rig is a dually!
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
