auxiliary fuel tanks - Ford Powerstroke Diesel Forum
post #1 of 3 Old 08-24-2013, 05:02 PM Thread Starter
I want to put an auxiliary fuel tank water tank toolbox combo an my truck and was wandering who makes the best tank. I heard a lot of good stuff about RDS tank. I also found a company called KSH marine but don't know anything about them looks like they have a good tank. Does anyone have one or know of them or any other good tanks.I was looking at northern tool #349804.
Late 1999 f350 4x4 drw crew cab auto trans, DI 4 position chip, AFE II air filter,ftvb, 4"down pipe into 2 5" stacks, ww, ccv mode, autometer gauges , 135,000 miles. Late 1999 f250 ext cab.4x4 auto FF stage 1 injectors non EBPV pedestal, GTP 38R turbo, hydra with powerstruck tunes, gauges. 213000 miles.
Jdg5147 is offline
post #2 of 3 Old 08-24-2013, 11:40 PM
JSchuricht's Avatar
I have had a KSH tank for about 5 years. No complaints with the quality of the tank but the locking cap option was junk. If I did it again, I would have had the filler moved closer to the front. Also they were a bit slow getting the tank built.
JSchuricht is offline
post #3 of 3 Old 09-07-2013, 03:35 PM
I had a TFI (Transfer Flow Inc.) 50gal aux tank on my last truck no major problems.
They are a automatic type tank system that keeps your stock tank full until they both reach the same gallon level, then as your stock tank drops by 3 to 5 gal it will transfer fuel until both tanks are at the same level again. There is never old fuel stting in the aux tank. I did have to replace the fuel pump once but they are easy to get parts from and parts are reasonably priced.
TX Twister is offline
