Aftermarket wheel bearings? - Ford Powerstroke Diesel Forum
post #1 of 10 Old 08-16-2013, 10:41 AM Thread Starter
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
Anybody have any idea if theres aftermarket support for wheel bearings out there? Of course the ones in my SD are going bad for obvious reasons. I just figured id see whats out there before throwing on some stockers that will just wear out in a few thousand miles.
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #2 of 10 Old 08-16-2013, 12:51 PM
schlutzer's Avatar
Quoted: 18 Post(s)
Ive had good luck with Timken brand in the past. Grand Am's are notorious for eating wheel bearings after the first set. tried 5 different brands in a year and the timkens are the only thing that held up.
The car was sold 4 years and 90 000kms later and the timkens were still going strong.
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
post #3 of 10 Old 08-16-2013, 12:52 PM
Quoted: 143 Post(s)
Feedback Score: 3 reviews
Not Cheap, but it will be the last you'll have to buy
Dynatrac - Confidence to ExploreŽ
NoRalPh is offline
post #4 of 10 Old 08-16-2013, 12:55 PM
JSchuricht's Avatar
I second the Dynatrac kit, especially with the tires your running.
JSchuricht is offline
post #5 of 10 Old 08-16-2013, 01:09 PM Thread Starter
Chapter Director
Quoted: 5 Post(s)
wow those dynatracs really hit the wallet hard but sure would solve the problem and for good. They may be a bit much for right now so i may try those timkins and save up for the dynatracs in the future. And would they work plain manual hubs since those are auto hubs?
Any other suggestions guys?
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #6 of 10 Old 08-16-2013, 04:00 PM
alaskan155's Avatar
Quoted: 60 Post(s)
i have the cheap master pro ones in mine from orielly's but i am running close to stock tire on mine, but have over 6k or so on them since i bought them a few months ago.
those dynatrac ones are nice, i think spin-tech makes one to, but i heard mixed reviews on quality
99-08 Ford SpynTec Overview | Spyntec Industries
2002 F250 7.3/JW Tow master 4r100 210k miles
Mods:explorer heater valve, WR GP relay, RiffRAff boots, lariat overhead console, Hydra chip, 6637 mod, 6.0 cooler, AIH delete and isspro2 trans, egt, and boost gauges. 92 gallon aux tank with a total capacity of 130gallons, 1800 mile range
, 4" MBRP straight Piped. 2" Warrior shackles
alaskan155 is offline
post #7 of 10 Old 08-16-2013, 04:15 PM
Quoted: 768 Post(s)
Timken is who makes the bearings for Ford. Don't buy the knockoffs. If you daily drive, they more than likely won't last a year, two at best.
I would be really surprised if dynatrac or spin tech didn't use timkens in their hubs. When it comes to automotive tapered roller bearings, there really isn't anyone better.
Corey@CNCFAB is offline
post #8 of 10 Old 08-16-2013, 05:00 PM
CSIPSD's Avatar
More Information for PRO 29515020
I've run a pair of these in my wifes excursion and one on my rig... Excursion has over 100k on them, mine has close to 80k...
Pretty sure the other side is going out...
You can replace A LOT of wheel bearings before coming close to the Danatrac kit...
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #9 of 10 Old 01-05-2014, 10:27 PM
boschert_72's Avatar
OP What did you end up doing? I'm curious about the spyntech kit, 600 off a dynatrac sounds tempting.
'99.5 F-250 SD PSD CCLB 4X4
Terminator Engineering, aFe, Airdog, Aeromotive, Skyjacker, Pink Stallion, Toyo M/T's, Fuel Octane 20x12's, Garrett, Banks, Diamond Eye, TransGo, Rockford Fosgate, Pioneer, Dp Tuner F6 Live, Aeroforce, BD Diesel, '11 Bed, '10 Bumper,'11 Tailgate, '05 HD heads, HID's, KC's(HID), Home-Made Traction Bars, 4KW Gear Reduction Starter, Ya know.... The Usual.....
Your gunna have to climb over a smokin pile of brass to get my guns!!
boschert_72 is offline
post #10 of 10 Old 02-01-2014, 08:01 PM
the1laf's Avatar
I had a wheel bearing & u-joint going out and bought a whole Dana 60 axle & got it installed an aligned for the price of the bearing, seal and u-joint..
In all seriousness if you have a Dana 50 I'd check your options like I did, tires 38"+ and the D50 don't play well together.. otherwise go with Timkin's until you can afford a Dynatrac kit.
Old thread... My bad.
2000 F-350 Lariat CCLB w. 335,000+ Mi
Tymar intake, Straight 4", 6.0 Intercooler, IDP Competition Fuel System, AC's, SB SD Clutch, ZF6 Short Shift Kit
Gearhead Tunes, Swamps IDM, Snow Performance Water/Meth, Isspro Performax Gauges & 08 Black Leather Seats
05 Harley's, Smoked tails, Weld Racing Sidewinder Wheels
Fried Piston, Re-building engine
330 RWHP Fuel Only - 363 RWHP w. Meth
Broke College kid... Eating Ramon to save for truck parts..
the1laf is offline
