HID Fix - Ford Powerstroke Diesel Forum
post #1 of 14 Old 08-05-2013, 06:45 PM Thread Starter
7 3 Powerstroke's Avatar
HID Fix
I'm installing HIDs on my truck. I'm pretty sure I have everything hooked up correctly, and everything works except for one of the high beams. Does anyone know what can be wrong?
2001 7.3L F350 Crew Cab, Long Bed, Dually.
Modifications: aFe Stage 2 CAI, 4" Flowmaster Exhaust with 7" Tip, XDP Compressor Wheel, Foil Delete, Glowshift MaxTow Gauges (Boost, EGT, and Pyro), and Tony Wildman 6 Position Chip.
7 3 Powerstroke is offline
post #2 of 14 Old 08-07-2013, 01:39 PM
Quoted: 3 Post(s)
did you try swapping bulbs to see if it was a bulb problem.
2000 DRW CC 7.3
Exterior: 08 Exterior Clone, 22.5's
Engine Mods: GTP38R WW2, 5 inch exhaust,T500, 6637, TW tunes,DI Up pipes, 6.7 fuel pump fuel system.
Trans Mods: 6.0 trans cooler, JW Valve body,Billet triple disc converter.
Sound Mods: 7" flip out tv, 3-way speakers all around, 12" sub, 500 watt amp.
Misc:dieselsite coolant filter, max ac assist, BRV, IHD,gauges, CCV
Next up power rear window
campbellflage is offline
post #3 of 14 Old 08-07-2013, 01:56 PM Thread Starter
No, I'll try it when I get off work.
post #4 of 14 Old 08-07-2013, 04:42 PM
Quoted: 3 Post(s)
I am still waiting on my kit to arrive, but from what I have read the high low beam is done with magnets in the bulb, so I would start there.
2000 DRW CC 7.3
post #5 of 14 Old 08-08-2013, 07:18 AM Thread Starter
I think it is a bulb issue because the same light wasn't working again. Although, the one that does work is having issues too. Now when I turn on my high beams it works on the drivers side, but when I turn my high beams off it still stays on high beam.
post #6 of 14 Old 08-11-2013, 06:57 AM
Quoted: 3 Post(s)
Idk. I got my kit in the mail yesterday, Mine didn't work right either, all wired up right, and one headlight came on that's it. Hope that the two different brands of hid ballasts are not gonna be a problem.
2000 DRW CC 7.3
post #7 of 14 Old 08-11-2013, 09:33 AM
Quoted: 3 Post(s)
hey I was having the same problem as you, just figured out what mine was. One of the connectors had a wire lose/out of place. Pushed it back all the way in, and lights work perfect.
2000 DRW CC 7.3
post #8 of 14 Old 08-11-2013, 11:36 AM
03ranger30's Avatar
Where do you guys get your HIDs from? Been looking for a kit for myself for a while.
Charlie
2003 F250 CCSB 7.3--Gearhead tuned, MBRP 5", 6637, Diesel Site Coolant Filter, 203* Thermostat, ISSPROs, HPx, 5% tint
03ranger30 is offline
post #9 of 14 Old 08-11-2013, 11:39 AM
Quoted: 3 Post(s)
I have two different brands. One I am not sure of where it came from, the other is from ddmtuning.
2000 DRW CC 7.3
post #10 of 14 Old 08-11-2013, 11:41 AM
03ranger30's Avatar
That's what I figured. I had them on my Ranger too. Were installing the bulbs with the high beams any different than the ones without? For me it was just plug and play.
Charlie
