Semi Horn Mounting - Ford Powerstroke Diesel Forum
post #1 of 4 Old 07-11-2013, 06:55 PM Thread Starter
7 3 Powerstroke's Avatar
Semi Horn Mounting
I was curious as to where I should/could be able to mount these Hadley semi horns.
Hadley Bully Series Horn Dual Horn Lanyard Activated
I was thinking about mounting them underneath the truck where the running boards bolt onto the frame.
TheDieselStop.Com - www.thedieselstop.com
But my mom raised up an excellent question. What happens if it rains and I get water in them? Will this happen if I mount them there? Will it even matter if I get water in them? Any help will be appreciated.
2001 7.3L F350 Crew Cab, Long Bed, Dually.
Modifications: aFe Stage 2 CAI, 4" Flowmaster Exhaust with 7" Tip, XDP Compressor Wheel, Foil Delete, Glowshift MaxTow Gauges (Boost, EGT, and Pyro), and Tony Wildman 6 Position Chip.
7 3 Powerstroke is offline
post #2 of 4 Old 07-12-2013, 06:15 AM
Quoted: 174 Post(s)
Feedback Score: 3 reviews
There are a TON of pictures here with Horn mounting. Do a Search, in this forum, under Train Horn, I'm sure you'd find some
Water isn't a big issue, you just need to pitch them slightly down so they drain. Under the bed, you would want to block sand & dirt from being thrown into them from the ft tire. I put my airtank about a foot in front of them (under the pass door) as a "blocker".
NoRalPh is offline
post #3 of 4 Old 07-12-2013, 06:25 AM Thread Starter
Thanks for the help. I'll have to wait until everything comes in to see all of my mounting options, and how I'll do it.
post #4 of 4 Old 07-12-2013, 06:53 AM
justinlogue5_0's Avatar
I have 4 air horns mounted together on the drivers side between body and frame pointing formard ,slight down lean for drainage and the actual train horns on the passenger side, mounted same way. Works great with plenty of room and you really can't see them doing a walk around. You have to lean down and really look for them.
A little bit of this and a little bit of that. I want a lot more of this and a lot more of that
It never ends!
justinlogue5_0 is offline
