To make chrome step rails BLACK - Ford Powerstroke Diesel Forum
post #1 of 20 Old 07-10-2013, 04:05 PM Thread Starter
Anyone have experience or tips on the best product or method? I've considered Chassis Saver, Monstaliner, and Plasti-Dip Sray. Have already Plasti-Dip sprayed my rims, and it turned out nice, and will maybe do the same to chrome bumpers, but plan on using Monstaliner on rocker panels and up over wheel wells. Much obliged for any ideas or experiences. Will get pics of the truck in my gallery when I get a camera that doesn't make it look like I was shooting thru a screen door
2001 F350 Lariat 7.3L 4x4 CC SB
BFG-AT 35x12.50R16.5, 4" Lift, Hutch Mod, TS Chip, 185,000mi...so far
RafterQ is offline
post #2 of 20 Old 07-10-2013, 07:00 PM
shawnb99's Avatar
have them sandblasted and powder coated
04 F-250 CCSB 4X4 6.0L Auto, tweaked by GEARHEAD
follow link to truck for sale
shawnb99 is offline
post #3 of 20 Old 07-11-2013, 07:05 AM Thread Starter
Considered that, but I'm on a type of Walmart-budget currently. Saw Rust-Oleum makes a bed liner spray, but I may still be stuck getting the chrome off the bars for that stuff to stick. Thanks for yer input!
RafterQ is offline
post #4 of 20 Old 07-12-2013, 06:18 AM
Quoted: 176 Post(s)
Feedback Score: 3 reviews
That RustOleum spray is real crap, it will rub-off no matter how you prepped the rail
NoRalPh is offline
post #5 of 20 Old 07-12-2013, 08:19 AM
I'm interested in this too. Tag
2000 f250
diy intake
4"straight pipe
ccv dumped outside
paulgl26 is offline
post #6 of 20 Old 07-12-2013, 08:25 AM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
Only way to have it hold up is with powdercoating. Its really not expensive as long as you pull the part and bring it to them. That being said my steps on my SD i tried plain spray paint and it came off the first few times i used it. Then i did the spray can bedliner and its held up better than the paint. Still not great but it would get you by until you can powdercoat them thats what im going to do.
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #7 of 20 Old 07-12-2013, 11:11 AM Thread Starter
Thanks, Pat. Might coat em with the bedliner and see if they hold up thru deer season, then I'll have the extra to do them right.
RafterQ is offline
post #8 of 20 Old 07-12-2013, 11:15 AM
Mine have some plastic. Can they still powder coat them?
2000 f250
diy intake
4"straight pipe
ccv dumped outside
paulgl26 is offline
post #9 of 20 Old 07-12-2013, 11:23 AM
Chapter Director
Quoted: 5 Post(s)
Youd have to remove the plastic because powder coating needs an electric charge through the metal for it to bond. I MAY be wrong because im not a powdercoater but my understanding is its for metal only.
Plus when you remove the plastic and powdercoat it, it adds a relatively significant thickness to the metal so the plastic may not go back on right so you should check that
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #10 of 20 Old 07-12-2013, 11:25 AM
Yep I'll try some bedliner paint next week. Have some sitting in the garage :-)
2000 f250
diy intake
4"straight pipe
ccv dumped outside
paulgl26 is offline
Tags
blackout , chrome , durable , nerfbars , step rails
