Pull the bed off? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 07-07-2013, 12:13 PM Thread Starter
Quoted: 17 Post(s)
Feedback Score: 3 reviews
Pull the bed off?
i am getting ready to order the strictly diesel hutch kit. i noticed most people pull the tank. is there a reason why no one slides the bed back? it seems like it would be easier but??
2000 F250 XcabSB, 4x4, 4" strait pipe, DIY intake, FRx, BDP tunes, WW2, 6.0 cooler, BTS VB, gauges, 55w digital projector HIDs
gomer pyle is offline
post #2 of 7 Old 07-08-2013, 12:00 AM
alaskan155's Avatar
Quoted: 65 Post(s)
i always wonder that my self, the ford beds are easy to remove, a couple bolts on the rear bumper, the bed bolts(torx bolts), wirings harness, and filler neck, and you could slide it back easily. or get a buddy and complete remove it.
every time i end up dropping a tank its a PITA to get it back in position, especially if there is fuel still in it.
2002 F250 7.3/JW Tow master 4r100 212k miles
Mods:explorer heater valve, WR GP relay, RiffRAff boots, lariat overhead console, Hydra chip, 6637 mod, 6.0 cooler, AIH delete and isspro2 trans, egt, and boost gauges. 92 gallon aux tank with a total capacity of 130gallons, 1800 mile range
, 4" MBRP straight Piped. 2" Warrior shackles, Redhead steering box
alaskan155 is offline
post #3 of 7 Old 07-08-2013, 09:46 AM
GregsSD's Avatar
Quoted: 15 Post(s)
Garage
If you have 3 friends with you then unbolt the bed and lift it off, or you can do what I did and unbolt the bed (leave the rear two bolts in, just loosen them), then use a floor jack and a piece of 4x4 to jack the front of the bed up so that you have access to the tank!
2005 F-250 CC/SB 4x4 medium wedgewood blue
5" lift, 5" Donahoe rear springs, 35x13.50 MTZ's, 18x12 Fuel Hostage wheels, 4.30 gears, Banks 4" exhaust, Airraid intake, SCT from Innovative, ARP headstuds, Bulletproof ficm, Bulletproof EGR cooler, Scangauge II, Randy Ellis Design lightbar, Street Scene flares, Harpoon mod, Zoodad mod, LED 2010 taillights, Switchback LED front turn signals
GregsSD is offline
post #4 of 7 Old 07-08-2013, 09:51 AM Thread Starter
Quoted: 17 Post(s)
I like that. Does it give plenty of room to get the pickup out?
post #5 of 7 Old 07-08-2013, 10:26 AM
rascal's Avatar
I dropped my tank. It wasn't that bad. However, getting it back in by myself was fun. I recommend having an extra set of hands to help.
Rascal
2000 F-350 XLT ECSB ZF6 4x4
38R+WW | Adrenaline HPOP | Optima | Ravelco | Mag Hytecs | Dynatrac | EBC | Strictly Diesel | AFE | Magnaflow | ISSPRO | DieselSite
rascal is offline
post #6 of 7 Old 07-08-2013, 10:27 AM
GregsSD's Avatar
Quoted: 15 Post(s)
Garage
Yes, this is how I accessed the tank to remove the sending unit to do the Harpoon mod. I highly suggest doing this mod also!
And you can pull out the pickup without having to unhook the fuel lines!
GregsSD is offline
post #7 of 7 Old 07-08-2013, 06:36 PM
goats's Avatar
Quoted: 2 Post(s)
i pulled the bed cause i have a forklift,its only 6 torx bolts 3 little screws and 2 elec plugs with a total time of 45 mins including having a beer.
goats is offline
