05-07 Tow Mirror wiring help - Ford Powerstroke Diesel Forum
post #1 of 3 Old 07-07-2013, 10:09 AM Thread Starter
the1laf's Avatar
My buddy has a small wrecker shop and managed to snag me a passenger mirror to match the drivers side replacement I wiped off several years ago..
The Problem:
The P.O. cut off the wires about 4" from where the mirror bolts on, not a big deal but I have 8 wires and everywhere I've read there should only be 7.
This looks like a true OEM mirror, it's solid unlike my aftermarket drivers mirror..
Black (Ground)
Blk w. W strip (Heat)
Brown (Marker)
Green (Turn Signal) Doesn't work..
Yellow (Glass adjustment Vertical)
Purple (Glass adjustment Vertical)
Yellow... ?
White... ?
I should only need 3 wires for adjusting the mirror but the other two wires do nothing no matter how I jump across them...
Any Ideas?
Thanks.
2000 F-350 Lariat CCLB w. 335,000+ Mi
Tymar intake, Straight 4", 6.0 Intercooler, IDP Competition Fuel System, AC's, SB SD Clutch, ZF6 Short Shift Kit
Gearhead Tunes, Swamps IDM, Snow Performance Water/Meth, Isspro Performax Gauges & 08 Black Leather Seats
05 Harley's, Smoked tails, Weld Racing Sidewinder Wheels
Fried Piston, Re-building engine
330 RWHP Fuel Only - 363 RWHP w. Meth
Broke College kid... Eating Ramon to save for truck parts..
the1laf is offline
post #2 of 3 Old 07-20-2013, 12:07 PM
yellow usually is the 12v+. is it thicker then the rest of em
lightn95 is offline
post #3 of 3 Old 07-20-2013, 12:13 PM Thread Starter
the1laf's Avatar
I'd have to pull the mirror again to look but then I wired everything else the two yellow wires looked identical. I tried jumping across different combinations with a hot wire from my battery but those last two wires didn't do anything.
the1laf is offline
