Help please - tow mirror, upper, popped out, need hints to replace - Ford Powerstroke Diesel Forum
post #1 of 3 Old 06-30-2013, 03:35 AM Thread Starter
I've an '02 with tow mirrors.
Limb fell on truck. First pic.
Top part of driver side rearview mirror POPPED OUT.
In the second pic I circled in red the pieces I know I got to slide back in, and it held for a while, but then the mirror fell out again.
I suspect I didn't get the "socket", circled in orange, to pop on.
I'm apprehensive to put to much pressure on it, I tend to break things.
Any suggestions on how to get it back together?
ID:	132362   Click image for larger version
'88 Ford 7.3 E350 Customized Maxivan
'09 VW JSW TDI (up to 47MPG highway)
'02 F350 DRW 4x4, 7.3 PSD, CC
tractors-'07 Kubota B7610
'95 Kubota M4700
gemniii is offline
post #2 of 3 Old 06-30-2013, 08:34 PM
dieselcrawler's Avatar
Quoted: 23 Post(s)
Just 'pop' it back in... untill the center ball is in the socket properly. If you push gently in the center in line with the ball you should be safe.
Greg
'99 E350 DRW Stahl 11' util box van, 7.3 PSD, stock. 138k SOLD
'00 F350 extcab, 9' utility bed, dually 228k
E'99 F250 extcab, S/Bed 211k. Sidelined due to motor issues.
'00 Excursion Limited, 7.3PSD 294k
'84 Chevy K-30, 6.2L TD, woods/trail beater. 141k
Semper Paratus
dieselcrawler is offline
post #3 of 3 Old 07-02-2013, 08:15 AM
importedaze300's Avatar
use a long set of needle nose pliers to get the pins back in for the mirror adjustment and line up all the pins then at the center of the mirror apply firm pressure until you feel it click
6637 filter
5" exhaust
bts valve body
gtp38r
no ebvp pedestal and exhaust outlet
oil feed line cross over
ts 6 position chip
6" lift
20" fuel wheels on 35s
2x4 to 4x4 conversion
2001 supercab 4x4 manual no mods
importedaze300 is offline
