Offroad light amperage question?? - Ford Powerstroke Diesel Forum
post #1 of 10 Old 06-24-2013, 04:43 PM Thread Starter
Ford Cowboy's Avatar
Quoted: 5 Post(s)
I'm in the process of installing nine kc 8" 130 watt lights on my truck(2000 7.3l 4x4 cclb). Two driving lights on front bumper along with two spots and then five spots along top of the headache rack. Each light pulls 10.83 amps. So 9x10.83=97.47 amps! Now, I wouldn't have all nine lights on all the time. Just occasionally. When I do have all nine on, what kinda strain is my electrical system gonna be under? Would it be worth it to have a second alternator installed? Thanks
cummin is the mess left behind by strokin!!
2000 7.3l f350 4x4 cclb psd. 4r100 trans.Ranchhand everything! 6637 intake, zoodad mod, custom big rig runnin lights, ccv mod, RR boots and plenum inserts, foil delete, EV2 gauges, edge cts, tuff country 2.5" leveling kit, X codes, 315/75r16 coopers, 08 mirrors, 6.0 trans cooler, tgc dual steering stabilizer, fabtech adj. trac bar, mbrp 5" turbo back straight pipe with 8" tip, php 6pos, ssbc brakes, ebpv delete, cat elc 100,xxx
Ford Cowboy is offline
post #2 of 10 Old 06-24-2013, 05:03 PM
gotta_gofast's Avatar
Quoted: 62 Post(s)
Why so many lights? If you need a premium light look into an LED baja bar. You're asking your electrical system to deliver almost 100 amps just for these lights. While the initial cost of LED bars may be expensive, factor in the price of nine halogens and a HD or dual alternators (and little things like 8-6awg wire and 100a relay).
'06 F250 FX4 6.0L typical bolt on
gotta_gofast is offline
post #3 of 10 Old 06-24-2013, 06:15 PM
Quoted: 17 Post(s)
Feedback Score: 3 reviews
i second led light bars but you may prefer the kc look. you will probably need a second alternator plus some big wires and relays. if you decide to put the 5 top lights on one switch you will need at least a 50amp relay and 6awg wire.
2000 F250 XcabSB, 4x4, 4" strait pipe, DIY intake, FRx, BDP tunes, WW2, 6.0 cooler, BTS VB, gauges, 55w digital projector HIDs
gomer pyle is offline
post #4 of 10 Old 06-24-2013, 06:39 PM Thread Starter
Quoted: 5 Post(s)
I prefer the kc look over the led. Ive been lookin at dc high output alternators. Mainly the 270 amp Xp and the 370 amp xp. Both of those put out 200 amps or more at idle. Any opinions on dc?
Just thought of something. Im gonna have all five lights on the headache rack come on at once. So, won't I need a switch that is rated for 50 amps or more??
post #5 of 10 Old 06-24-2013, 06:44 PM
PowerStrokedRedneck's Avatar
I had 5 of the 130 watt KCs on the roof and 2 PIAAs on the brush guard of my Ranger and never had a power issue. In the 10 years and 90k miles never put an alternator in it either. I had 1 switch turn 3 relays on. So no more than 2 lights on one relay/circuit. I love LEDs but you can't beat the look of a row of KCs across the cab.
Sent from AutoGuide.com App
PowerStrokedRedneck is offline
post #6 of 10 Old 06-24-2013, 06:56 PM Thread Starter
Quoted: 5 Post(s)
Ok I had a brain fart. That's how u do it. How'd I come up with 50 amp switch hahaha
post #7 of 10 Old 06-25-2013, 08:54 PM
russtwentyfour's Avatar
Or you could have a look at these.
Lights Lzr Led Lzr 8 Rnd 35w Led KC HiLiTES: Auxiliary Lighting, Off Road Lights, HID Off Road Lights, Fog Lights, LED Light Bars, Driving Lights, Light Bars, Wiring Accessories, Flashlights, Torches
E99 F350 Ext. cab Long bed, single wheel 2x4
Riff Raff 6637 intake, FRX and HPX,
Dieselsite boostfooler, factory tech valvebody, filter system,
Local custom trans build - BTS in near future,
Derale cooling pan and trans cooler,
Mbrp 4" turbo back
Ts 6 pos chip - TW tunes coming soon,
Guzzles hutch and harpoon mod with lift pump and racor filters
Ww2
Blank pedestal with moded exhaust port
Afe rear end cover
Callahan drilled and slotted rotors front and rear
russtwentyfour is offline
post #8 of 10 Old 06-26-2013, 01:52 PM
Quoted: 62 Post(s)
$5000 in lighting for nine of those suckers!
post #9 of 10 Old 06-26-2013, 05:32 PM
Oh wow I never looked at the price, lol! Sorry guys scrub that thought! Haha
Mbrp 4" turbo back
Ww2
Afe rear end cover
post #10 of 10 Old 06-27-2013, 10:15 AM
jdereu's Avatar
6" Off-Road Light System
I have 4 of these on mine i really like them one day ill convert them to hid
2000 Ford F-250, Crew Cab Long Bed 4x4, Automatic Transmission, Ts 6 Position, 4" MBRP Exhaust, DIY Intake, Pillar Guages, CCV Mod
jdereu is offline
