Fog light mod - Ford Powerstroke Diesel Forum
post #1 of 8 Old 06-24-2013, 09:55 AM Thread Starter
superjoey03's Avatar
Fog light mod
Just wondering if anyone knew how to fix the headlight switch so that you can turn your fog lights on with the parking lights? I've seen numerous truck this way but I don't know if its a different headlight switch from a newer truck or if they just installed a separate switch.
superjoey03 is offline
post #2 of 8 Old 06-24-2013, 09:56 AM Thread Starter
Maybe there is a sticky?
post #3 of 8 Old 06-24-2013, 10:01 AM
04sblightning's Avatar
Feedback Score: 4 reviews
I have an 02 and it does it from the factory. If you do a search on google I know a lot of Lightning guys do it to their trucks and it's not bad.
04sblightning is offline
post #4 of 8 Old 06-24-2013, 10:04 AM
mrc228's Avatar
If you don't have the pull out switch that works the fog lights, wire a relay to turn on with the parking light 12v. Wire the normally open side from the battery through an inline fuse suitable for the current draw and then to the lights. Be sure you use big enough gauge wire for the lights too.
Sent from AutoGuide.com App
'06 F250 CC FX4 - 127k miles
Under the hood
EGR Delete, Upgraded oil cooler, upgraded stc fiting /w new HPOP, Blue Spring, 4" Turbo Back, SCT tuner /w Wildman Extreme & Street tune, Sinister Diesel Coolant Filter
studs to come
In the cab
Pillar Glowshift gauge package (EoP/Fuel press/EGT), Dashboss
Alpine touchscreen nav head unit, bluetooth, Phoenix Gold 4-channel amp, JL Audio's 6.5 components up front, 5x7's in rear doors, 10" sub behind seats.
mrc228 is offline
post #5 of 8 Old 06-24-2013, 10:08 AM
mrc228's Avatar
Quick drawing on the back of my lunch receipt!!! Lol
Under the hood
studs to come
In the cab
mrc228 is offline
post #6 of 8 Old 06-24-2013, 01:12 PM Thread Starter
I do have the pull out switch.
post #7 of 8 Old 06-24-2013, 01:13 PM Thread Starter
Maybe I'll grab on out of an 02 and see if it does it or not.
post #8 of 8 Old 07-02-2013, 03:23 PM
codyryan07's Avatar
IIRC, theres a little white tab that needs to be filed down on the backside of the switch. I'll look to see if i can find a link to it again.
Cody Ryan
03 f250 ccsb fx4 7.3
4" RC lift
35x12.50 federals on 20x12 rockstars
6637 intake, straight pipe
full RR w/ fuel bowl delete.
rebuild coming soon
codyryan07 is offline
