RECON headlights will not fit??? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 06-16-2013, 07:34 PM Thread Starter
WTH! am i doing wrong? new recon headlights will not fit my 02 hitting on one side of the headlight bucket. I have checked part # all call out for the same year? Ant ideas? i will call them in the A.M. just trying to find out WTH!
fomoco is offline
post #2 of 4 Old 06-16-2013, 08:04 PM
russtwentyfour's Avatar
Mine did that and the headlights I ordered turned out to be for the later model header panel. I just trimmed my header panel till they fit without touching anywhere and they have been great.
E99 F350 Ext. cab Long bed, single wheel 2x4
Riff Raff 6637 intake, FRX and HPX,
Dieselsite boostfooler, factory tech valvebody, filter system,
Local custom trans build - BTS in near future,
Derale cooling pan and trans cooler,
Mbrp 4" turbo back
Ts 6 pos chip - TW tunes coming soon,
Guzzles hutch and harpoon mod with lift pump and racor filters
Ww2
Blank pedestal with moded exhaust port
Afe rear end cover
Callahan drilled and slotted rotors front and rear
russtwentyfour is offline
post #3 of 4 Old 06-22-2013, 06:15 PM
Did you get it to fit? I put some aftermarket lights on my truck and had to hack the backing until they went in. Looking back on it I wouldn't do it again, modifying the stock ones would have been a better option.
2000 F250 7.3L Powerstroke
DP Tuner, RifRaff Intake, 4" Exhaust
Tahoe_Bear is offline
post #4 of 4 Old 06-23-2013, 09:07 PM
Lambo3244's Avatar
Quoted: 4 Post(s)
On my 2001 they said they said trimming was not involved but there was for me. Just took a wheel and cut back some of the fiberglass to make them work. Once I got everything trimmed and fitted they worked great!
01
7.3L Powerstroke
PHP Hydra Chip
G2 Brute Diff Covers
4'' Straight Pipe
Rigid Industries LEDs
AFE Stage II Intake
AMP Power Steps
BD Comp. Wheel
Fox 2.0 Factory Series Reservoir Shocks
Fox Dual Steering Stabilizer
Katzkin Leather
Lambo3244 is offline
