LEDs in turn signals - Ford Powerstroke Diesel Forum
post #1 of 7 Old 06-13-2013, 06:57 AM Thread Starter
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
Hey guys i ordered some leds for my tailights and rear turns and i got the hyperflash of course and i know you need a resistor but then i though about it and they wont work because they dont have the 2 phase light(one for night brake lights and one for when you actually are braking) do you guys know of any plug and play ones preferably with built in resistors that have the 2 phase lighting?
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #2 of 7 Old 06-13-2013, 10:15 AM
Quoted: 16 Post(s)
Feedback Score: 3 reviews
Recon or anzo but you have to buy the whole light
2000 F250 XcabSB, 4x4, 4" strait pipe, DIY intake, FRx, BDP tunes, WW2, 6.0 cooler, BTS VB, gauges, 55w digital projector HIDs
gomer pyle is offline
post #3 of 7 Old 06-13-2013, 01:41 PM
GregsSD's Avatar
Quoted: 15 Post(s)
Garage
When you say "night brake lights", are you talking about the tail lights? Never heard anyone call them night brake lights.
You don't need to add any resistors when you switch to leds, all you need to do is change out your flasher under your dash with a newer "Electronic" flasher. The electronic flasher will flash at the same speed whether you are using standard bulbs or leds.
Here is one that will work: http://www.autozone.com/autozone/par...ntifier=247231
2005 F-250 CC/SB 4x4 medium wedgewood blue
5" lift, 5" Donahoe rear springs, 35x13.50 MTZ's, 18x12 Fuel Hostage wheels, 4.30 gears, Banks 4" exhaust, Airraid intake, SCT from Innovative, ARP headstuds, Bulletproof ficm, Scangauge II, Randy Ellis Design lightbar, Street Scene flares, Harpoon mod, Zoodad mod, LED 2010 taillights, Switchback LED front turn signals
GregsSD is offline
post #4 of 7 Old 06-13-2013, 01:44 PM Thread Starter
Chapter Director
Quoted: 5 Post(s)
Well i couldnt think of the word, the running lights. the ones that come on when you turn your lights on. but its way easier and cheaper just to splice a resistor in parallel with the the tailights.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #5 of 7 Old 06-13-2013, 01:56 PM
GregsSD's Avatar
Quoted: 15 Post(s)
Garage
It might be a little cheaper, but you have to make sure to get large enough resistors and then splice one into each of your tail lights. Then make sure that you seal then up good so they don't corrode.
Changing the flasher is just a matter of unplugging the old one, then plugging in the new one. Much easier!
GregsSD is offline
post #6 of 7 Old 06-13-2013, 02:02 PM Thread Starter
Chapter Director
Quoted: 5 Post(s)
Already know which ones 50W 8 ohms. but i can run to my local radio shack to get resistors vs having to order the flasher. And dont worry about corrosion i live in a salt state and i dont have any rust yet so id say my little resistor will be fine
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #7 of 7 Old 06-13-2013, 06:58 PM
Quoted: 16 Post(s)
Greg that is a good find. $16 and i don't have to splice into my wiring! I'm in
