Rusted rear wheel wells - Ford Powerstroke Diesel Forum
post #1 of 16 Old 04-23-2013, 11:07 AM Thread Starter
I was wondering if I got rust that expands about two inches above the lip on my rear wheel wells. What is the easiest way to fix that problem not just cover it up and let it worsen.
carmichaelk is offline
post #2 of 16 Old 04-23-2013, 11:24 AM
Patch panels are really the only permanent fix.
And wash wash wash.
Sent from AutoGuide.com App
2001 F350 SRW CC 4WD LB
ZF6 w/ Southbend, 220k, DIY Intake, WW,NonEBPV Pedestal, CCV Mod, Gauges (Boost, Pyro), 2in Leveling Kit, 4" Straight MBRP, AIH Delete, 2-12" Kicker Comp's, Pioneer Amps
2001 F350 DRW EC 2WD (Rolled Over)
2000 F550 CC 2WD
Automatic, Jasper 4R100 w/Derale Pan & 6.0 Cooler, DIY Intake, AIH Delete, 4" MBRP,
Schnot is offline
post #3 of 16 Old 04-23-2013, 01:08 PM
ANything you do will be a cover up except for replacement. People say Por15, but that won't do it since what you are seeing is rust from behind that starts where the inner wall and the outer wall combine. This area is a trap for salt, water, and mud and will rot. Paint over it, it will be back.
2000 F350 4wd CC SB PSD
Normal mods plus gauges and PHP chip
Lowered to F250 height
Stock tire size, looks stock.
18' 10k# equipment trailer
30' Travel Trailer 7500#
Kioti CK30 tractor
Kawasaki KLX250s Dual Sport
Highbeam is offline
post #4 of 16 Old 04-28-2013, 12:35 PM
Silver200273L's Avatar
I have the same problem. I just looked at Rock Auto and they sell sheet metal that is all ready to go. All you got do is trace a line n cut old one off and put new sheet metal on it and weld it. Then do the paint job.
DP Tuner
Dieselsite Wicked Wheel II
5" Straight Pipe
6637 DIY Intake
Riffraff Intercooler Boots
Riffraff CCV
Harley Davidson Headlights Conversion
05-07 Grille
2.5 Leveling Kit
33" BFGoodrich All Terrain
LED tail lights
Billet Grille
Line of Fire
Silver200273L is offline
post #5 of 16 Old 04-29-2013, 05:59 AM Thread Starter
so if it isnt rustede all the way through should i try to grind it down and paint it or grind it and remove the rust and get fender flares
post #6 of 16 Old 04-29-2013, 06:23 AM
2000-7.3L's Avatar
Feedback Score: 10 reviews
This is what i did this weekend!
Rusted rear wheel wells-imageuploadedbyautoguide1367241779.004572.jpgRusted rear wheel wells-imageuploadedbyautoguide1367241788.674270.jpgRusted rear wheel wells-imageuploadedbyautoguide1367241805.403266.jpgRusted rear wheel wells-imageuploadedbyautoguide1367241817.576735.jpg
2000-7.3L is offline
post #7 of 16 Old 04-30-2013, 02:16 PM
That look like ***. Wouldn't rust have been better? It's still rusting under all that goop.
Kioti CK30 tractor
Highbeam is offline
post #8 of 16 Old 04-30-2013, 03:36 PM
2000-7.3L's Avatar
My rear quarter looks like crap??
post #9 of 16 Old 04-30-2013, 03:52 PM
2000-7.3L's Avatar
so what would you have done to idk fix rust?
post #10 of 16 Old 04-30-2013, 05:01 PM
Quoted: 144 Post(s)
Feedback Score: 3 reviews
Yea, it does look like crap Sorry...
To fix it right you weld in a new piece, then find somebody who can actually do bodywork to fill & sand it in so you can't see the repair
NoRalPh is offline
