Hood adjustment?????? - Ford Powerstroke Diesel Forum
post #1 of 8 Old 04-16-2013, 04:47 PM Thread Starter
Ford Cowboy's Avatar
Quoted: 5 Post(s)
Just got my truck back from the body shop last week and noticed that I have to slam the crap out of the hood to get it to lock shut. I don't remember it being that hard before the body shop. I'm just afraid that over time something's gonna break. Is there something I can adjust so it ain't so hard??? Thanks
Ford Cowboy is offline
post #2 of 8 Old 04-17-2013, 11:56 AM
layson's Avatar
Quoted: 82 Post(s)
There are only a couple things to mess with. The latch and the rubber stops on the sides of the hood.
So maybe the latch got messed with and was lowered down slightly. So the stops on the sides could be high which makes it harder to shut. Or the latch is bent/damaged?
All the lines around the hood/grille/headlights still look correct. Does it pop up easily when you pull the latch? Or does it pop up real abruptly like the hood is under some load... LOL. Just thinking the latch might have been lowered or damaged...
2001 - 14" OUO 525 - 38x15.5x20 Toyo & 20x12 Weld Cheyenne's. Hybrids, 38R, BTS, Spearco, Terminators..
Quote of the Day:
Originally Posted by Mannysouza View Post
You will get some axle wrap with a heavy trailer, I can feel it when towing my gooseneck with some heavy equipment. My Deavers will wrap enough to make the tires rub the front of the rear fender well if I give it too much throttle on aceleration.
layson is offline
post #3 of 8 Old 04-17-2013, 11:59 AM
2000-7.3L's Avatar
Feedback Score: 10 reviews
Latch could be sticking closed, had the problem before.
~ How are you line gaps between the fenders? Even?
~ Body lines all staright?
2000-7.3L is offline
post #4 of 8 Old 04-17-2013, 12:39 PM
LOTTS73's Avatar
Bring it back to them and have them adjust it.
01 F-350 7.3 Auto/6637 mod/Muffler delete/Pillar gauges
LOTTS73 is offline
post #5 of 8 Old 04-17-2013, 04:24 PM Thread Starter
Quoted: 5 Post(s)
I adjusted the rubber stops and it is MUCH better.
post #6 of 8 Old 04-17-2013, 06:02 PM
Macon's Avatar
Is it much better, or is it fixed? Since it's closing better now, check the body lines. With it closed, gaps should be 1/8-1/4", and the same all around. If it's not on straight, go back to the shop and ask them to fix it. I'm all about fixing stuff myself, but I try to not touch someone else's work.
2002 F250 CCSB 4x4
PHP Phoenix, John Woods VB, NUC bypass, 6637
"No country can be called free which is governed by an absolute power;
and it matters not whether it be an absolute royal power or an absolute
legislative power, as the consequences will be the same to the people."
--Thomas Paine, Four Letters on Interesting Subjects, 1776
Macon is offline
post #7 of 8 Old 04-19-2013, 03:05 PM Thread Starter
Quoted: 5 Post(s)
Went by the body shop today and they realigned fender and adjusted the hood latch. Everything looks and works like it should
post #8 of 8 Old 04-19-2013, 03:08 PM
Macon's Avatar
Very good.
2002 F250 CCSB 4x4
Macon is offline
