RUST - Ford Powerstroke Diesel Forum
post #1 of 6 Old 04-13-2013, 06:40 PM Thread Starter
jnightrod's Avatar
RUST
Just trying to get some insight on what to do. I bought a '03 F350 supercab long bed from up north that had a rust problem. I replaced the bed with a '08 due to the original being rusted away completely. The issue I have now is all four doors are ate up with rust on the bottom, the rocker panels on both sides are about 30-40% gone, and both cab corners are rusting out now. I dont want to just junk the truck since it only has 150K miles and nothing is wrong with it mechanically. Is it better to find a junk truck and swap the cabs or try replacing all four doors and weld patches to the body were the rust is? I have no idea what either option would cost? Its a really nice truck just this rust issue is really getting to me. Thanks.
jnightrod is offline
post #2 of 6 Old 04-13-2013, 06:42 PM
tkobes43's Avatar
Quoted: 2 Post(s)
Garage
Rust is a killer, I know you can get rocker panels, and cab corners still. If you can weld them in yourself then i would do that... Im not to sure about the floors tho.
Tom
5" MBRP Straight Exhaust w/ 6" tip, SCT Monitored, Limo Tints, 20" LED Lightbar, 8k HIDS, & Some other goodies
Other Rides
1978 Trans Am Y88 403 84k original miles
1996 Ford F350 PSD Mason Dump 134k Original Miles!
Gone But Not Forgotten... (Lilah) 2008 Ford F250 Lariat CrewCab
Proud To Be An American!
tkobes43 is offline
post #3 of 6 Old 04-13-2013, 07:46 PM
E99F350Stroker's Avatar
http://m.jcwhitney.com/repair-panels...d50405y2003g55
The website above has replacement rocker panels and cab corners. If you can weld it would be cheaper to replace the panels your self. Assuming you can weld and are able to replace the panels you still need to consider how much paint and body filler cost. Even if you could not replace it your self the body work would still probably be cheaper than finding a replacement cab. It's hard to judge because it honestly depends on what your specific standards of quality is.
Jordan
*Sold* Early 99 F-350 dually 4x4 6spd 7.3
*Sold 2000 F-250 4x4 ATS auto 7.3
1996 Dodge 2500 4x4 speed, 12 valve cummins, 283000, stock
E99F350Stroker is offline
post #4 of 6 Old 04-14-2013, 03:35 AM Thread Starter
jnightrod's Avatar
Im not the best at welding nor the worst, but im not necessarily looking for show quality. I thought about if I did the patch repairs that I would paint the bottom side of the truck with rhino liner. I appreciate the feedback.
post #5 of 6 Old 04-14-2013, 06:39 AM
tkobes43's Avatar
Quoted: 2 Post(s)
Garage
Rhino liner is a very good idea!! My buddy did it on his 250 and it does look good, and is VERY rugged! PITA to get the mud off tho.
Tom
Other Rides
tkobes43 is offline
post #6 of 6 Old 04-15-2013, 06:43 AM
Rhino liner would look good. It's durable too
Jordan
