Truck repair/'05 Upgrade - Ford Powerstroke Diesel Forum
post #1 of 4 Old 04-12-2013, 03:51 AM Thread Starter
I know there have been a lot of threads with '05 front end conversion but what's one more.
A couple weeks ago a car decided they wanted to exit at the last minute and cut me off. I got on the brakes, , and the back tires locked since the roads were wet and I went into the wall. It didn't cause too much damage but I needed to replace the fender, inner fender, bumper, header panel, and headlight so I figured now would be a good time to do the '05 front end upgrade.
Pics after the wreck.
I got everything taken off that needed to be replaced. The bottom of the door pulled out nicely with only a chip of paint missing from the fender smashing into it. Once I got everything off I noticed that I will need to do a little work on the radiator/fender support and pull it back out.
I decided since the front end was off, and I put a new transmission in less than 400 miles ago, that now would be a good time for the 31 pass transmission cooler. $110 shipped
I got the damaged part of the radiator/fender support pulled out and repainted. It's not perfect but everything fits properly.
I got the fender and bumper cover back from paint and started the reassembly. I still need to get the pin striping tape and then it will be 100% done.
Complete minus the pin stripes.
2001 F-250 Lariat SC LB
130,000 miles
Bone Stock (for now)
raw109 is offline
post #2 of 4 Old 04-17-2013, 11:32 AM
LOTTS73's Avatar
Looks good! I dig the later model headlights!
01 F-350 7.3 Auto/6637 mod/Muffler delete/Pillar gauges
LOTTS73 is offline
post #3 of 4 Old 04-17-2013, 07:01 PM
wireman116's Avatar
Wow looks good.
wireman116 is offline
post #4 of 4 Old 04-19-2013, 06:11 AM Thread Starter
Thanks guys. I'm pretty pleased with it.
130,000 miles
raw109 is offline
