Rim and Tire Questions - Ford Powerstroke Diesel Forum
post #1 of 4 Old 04-04-2013, 10:38 AM Thread Starter
FrankDeford's Avatar
Im looking to get some new wheels and tires for my 01 f250 four wheel drive stock suspension. I found some black and machined 17 inch helos that I like, and 33 12.50 wrangler duratracs. My problem is the rims only come eight inches wide. 8 to 12.5 kind of scares me especially on a heavy truck, i dont tow a lot but also dont want to eliminate that ability. Basically should I worry about this rim width and tire width combo for our trucks concerning performance or looks? Searching around for a decision was making my head hurt so I just figured Id ask here for a reliable answer. Thanks
2001 White Ext Cab Short Bed
Gauges
Exhaust
DP Tuner
5% Tint
Pro Comp 1079's
FrankDeford is offline
post #2 of 4 Old 04-04-2013, 10:55 AM
GregsSD's Avatar
Quoted: 15 Post(s)
Garage
That tire is recommended for use on a 8.5" - 10" wide rim so I would look around for some other rims if you want the best performance out of them.
They will fit fine on 8" wide rims but like you say, cornering and load hauling performance may suffer.
Tire Rack has a chart showing tire specs: http://www.tirerack.com/tires/tires....eMake=Goodyear
2005 F-250 CC/SB 4x4 medium wedgewood blue
5" lift, 5" Donahoe rear springs, 35x13.50 MTZ's, 18x12 Fuel Hostage wheels, 4.30 gears, Banks 4" exhaust, Airraid intake, SCT from Innovative, ARP headstuds, Bulletproof ficm, Scangauge II, Randy Ellis Design lightbar, Street Scene flares, Harpoon mod, Zoodad mod, LED 2010 taillights, Switchback LED front turn signals
GregsSD is offline
post #3 of 4 Old 04-04-2013, 12:16 PM
Macon's Avatar
You should find a different wheel, or find a narrower tire. These are heavy trucks, you really shouldn't go "close enough" on the only thing keeping your bumpers from digging into the pavement. I'm not saying to go out and spend thousands of dollars, but you should invest in a combination that works properly.
2002 F250 CCSB 4x4
PHP Phoenix, John Woods VB, NUC bypass, 6637
"No country can be called free which is governed by an absolute power;
and it matters not whether it be an absolute royal power or an absolute
legislative power, as the consequences will be the same to the people."
--Thomas Paine, Four Letters on Interesting Subjects, 1776
Macon is offline
post #4 of 4 Old 04-04-2013, 02:23 PM
HOODY's Avatar
make sure to check the load rating for the wheels even some steel wheels are not up for the weight of these trucks..
HOODY is offline
