Mirror Wiggle - Ford Powerstroke Diesel Forum
post #1 of 7 Old 03-29-2013, 09:04 AM Thread Starter
F350Bigfoot's Avatar
Angry Mirror Wiggle
Is there any way to fix/stop the exterior tow mirrors from wiggling ,wobbling, shaking while driving? Its getting to a point that they are useless now to try to see behind you.
Thanks
F350Bigfoot is offline
post #2 of 7 Old 03-29-2013, 12:15 PM
The Maddawg
maddawg89's Avatar
Quoted: 280 Post(s)
Feedback Score: 3 reviews
is it in the knuckle, or at the door where it connects up? Im assuming knuckle.... Im not sure.... Looks like the only way is to replace....
2005 F250 6.0 Powerhouse Lariat
Bully GT Platinum with Quick Tricks
Bully Dog intake
Everything else stock.
Moto Metal 18in rims wrapped in 275/70 Mud Claw Extremes
2003 F250 cclb flat bed.
All stock 7.3 turtle
maddawg89 is offline
post #3 of 7 Old 03-29-2013, 03:27 PM Thread Starter
It is just the mirror glass itself. Not the full assembly. Sorry for confusion.
post #4 of 7 Old 03-30-2013, 05:41 PM
Codum's Avatar
If its is the glass itself you should be able to fix it. You will need to pull the glass out, yes pull it out. The metal clips inside and plastic guides are what's lose. You will need to pry on the metal clips to tighten them up then reinstall. I just replaced both my mirror assembles as I had a wobble in the knuckle. Good luck!
2002 F250 CCSB Lariet 7.3 Auto
2" helper springs 285/75R16 Toyo M/T
80 gallon fuel tank in bed
DIY 6637
Warn Premium Hubs
Ford Transmission @ 407,425 miles 3/24/12
Full Force Injectors
Avic X930BT w/ backup camera
"We Farm for Ducks"
As of 6/11/16 605,552 miles
2005 Excursion Eddie Bauer 4X4 6.0
Stock 225k miles
Codum is offline
post #5 of 7 Old 03-30-2013, 06:00 PM Thread Starter
How do you pull it out? Turn it to a side and pry or?
post #6 of 7 Old 03-30-2013, 06:23 PM
Codum's Avatar
If its power then power it all the way in so the outer edge is exposed. Grap it and pull. I like to make it a quick snatch, seams to be less stress on the glass.
DIY 6637
Warn Premium Hubs
"We Farm for Ducks"
Stock 225k miles
Codum is offline
post #7 of 7 Old 03-30-2013, 08:01 PM Thread Starter
Thanks. I will give it a yank in the morning. Lol
