Lifting a 450 - Ford Powerstroke Diesel Forum
post #1 of 2 Old 03-14-2013, 08:01 PM Thread Starter
Lifting a 450
How difficult is it to buy a lift kit for a 99 f450 cant seem to find anything at all someone please helppp
h2mets is offline
post #2 of 2 Old 03-15-2013, 07:57 AM
Tj Krawler's Avatar
A normal SD lift will fit with some changes. You will only get the normal suspension instead of the F-450 springs. If you tow heavy you might need to get airbags to make up the difference. Unless you choose to get blocks instead of a spring lift for the rear.
The axle tube is larger, so you will need bigger U bolts for the back.
There might be some other differences, but that's all I know of.
Alan
2000 F-350 CC LB DRW 4x4 XLT Auto
- Intake
- Exhust
- ScanGauge
Tj Krawler is offline
