CB Antenna's - Pic's and recommendations - Ford Powerstroke Diesel Forum
Old 02-04-2013, 08:10 AM
Premium Starfish Member
Been a while since I've had to think about this, but I'm going to be updating my
gear, as well as needing some advice - and I'd like to see some pic's of your antenna's
and mountings.
I'm planning on taking a simple approach to this and right now looking at possibly doing
1 1/2 to 2 ft. single rod on, on both mirrors.
Now, I'm not dead set in my ways - but I'd like to see what others have done and could use some ideas for some clean appearances.
If anyone already has that setup - what sticks are you using and how do you like them?
Old 02-04-2013, 11:12 AM
Ill be keeping an eye on this Im in the same boat. here is one I found somewhere a while back and I think I kinda like the idea. Its clean and looks almost kinda "factory" which i like. 2004 F250 CB Antenna Install
Old 02-04-2013, 09:05 PM
Re: CB Antenna's - Pic's and recommendations
Master CB thread
Tons of ideas
Old 02-05-2013, 04:34 AM
no the best photo and probably dosent help if you dont have a bar but ive just got mine mounted on the bullbar, looks alot bigger then it is in this pic, it sits about 30mm above the snorkle
CB Antenna's - Pic's and recommendations-227824_10151204697965050_1572445624_n.jpg
Old 02-05-2013, 07:42 AM
I've seen that thread before. I didn't want to thread jack it as I was looking more just for Antenna mounting locations for EX's rather than anything else.
Old 02-05-2013, 08:32 AM
Ah yes, I forgot you have an ex. There's a few mirror mounts and such on there. Good luck, im looking at mounting up a cb soon.
