Removing f-350 fender and door badges - Ford Powerstroke Diesel Forum
Old 12-21-2012, 09:15 AM
ok so i want to remove my f350 fender badge and my diesel v8 door badges. What is the proper procedure? Any pics? what to expect? i.e. what holds them on? is there any holes? paint discoloration? thanks alot for the help guys.
Old 12-21-2012, 02:50 PM
I recommend using some heavy fishing wire. There are alignment holes on the fender so if you plan on leaving them off, u will have holes. U may also break the alignment tabs. U will also need to remove the left over tape from the body where they were mounted. Some Commercial aerosol goof off works great. As for the door badges, no holes behind them.
