2000 F250 level questions? - Ford Powerstroke Diesel Forum
Old 11-06-2012, 03:06 PM
i recall reading a thread a bit back about excursion front leafs will give an F250 a level stance.
they 1-2" taller?
my truck 2000 f250 (245k miles) diesel
his 2005 excursion (65k miles) gas
reason im asking is there's a local guy that yarded his (65k miles) for a 5" lift kit.
thinking i can possibly use them for a "level" stance on my Superduty.
thoughts, options, references appreciated.
the only numbers on the springs i can make out are
3034AHA and RPN2924
thanks in advance
Old 11-06-2012, 03:50 PM
also-
what other parts (if any) would i need to make this home made kit install-able?
Old 11-06-2012, 07:10 PM
first off, 2005 was the first year that ford went to coil springs in the front vs leaf springs in the super dutys. from what i know about excursions is they carried a lighter spring in the front than 250s and 350s even with the diesels. all leaf spring 250s and 350s had v code springs. x codes were for the plow package and would level a 350.
Old 11-06-2012, 07:16 PM
that about sums it up.
excellent info, in my opinion.
thanks
Old 11-06-2012, 08:00 PM
because i like to know.... i looked it up. it looks like the 05 excursions still had leaf springs. but, i know that ex owners are going to super duty springs to get rid of the sagging wallowy springs. not the other way around.
Old 11-06-2012, 08:04 PM
you should have v code springs, confirm this with your door code. i bought my 99 at 191k and the springs were sagging. i bought a shackle lift for mine. i also had a shackle lift with my 03 and ad no problems with it. cheap and easy
Old 11-07-2012, 08:57 AM
Feedback Score: 5 reviews
Excursion springs are not rated to carry the weight of a diesel...will drop the front 2" lower than a V code.
As stated you could get a 2" hangers or a 2" mini spring pack and remove a leaf or 2 to get the height you want. We have all..
Old 11-08-2012, 10:36 AM
shackles on way.
simple solution.
thanks all
Old 11-14-2012, 09:03 PM
I got all skyjacker pieces and an add a leaf for mine 2000 F250 level questions?-imageuploadedbyautoguide1352959358.488613.jpg before 2000 F250 level questions?-imageuploadedbyautoguide1352959377.736389.jpg and after
Sent from my iPhone using AutoGuide.com App
Old 12-05-2012, 08:38 AM
update~
got some 2" shackles....got the truck apart but the axle doesnt want to line up under the truck.
did anyone need to install a trackbar relocator?
