How to adjust the beam on my 05-07 harley headlights - Ford Powerstroke Diesel Forum
Old 10-22-2012, 08:25 PM
I picked up my truck 1999.5 CC LB F350 DRW JGFNOVA couple weeks ago and getting comfortable with it. It came with the 05-07 harley headlight conversion. It looks great but at night the beam is way to low.
I have been running my high beams all the time and haven't been flashed one time. How can I adjust the beams up on these headlights? The low beams shine maybe 30-35 feet till the beam is completely lost.
Old 10-22-2012, 09:19 PM
EDIT: Sorry about that.......Don't know what I was thinking.
Old 10-22-2012, 09:47 PM
Originally Posted by SuperCrutyPS View Post
Thanks SuperCruty, but not sure you got the right link.. those are for a harley motorcycle headlamps ..
and I did search the forum before I posted
Old 10-22-2012, 11:30 PM
There should be an adjustment knob on top of the housing in my 05 lariat I believe it was white. Think you need either a wrench or screwdriver to adjust can't remember though.
Old 10-23-2012, 01:48 AM
It's like a reverse torx bit on top of the headlight towards the inner side of the light. Towards the center of the truck. Should be able to turn it with a pair of pliers if you don't have the correct socket.
Old 10-23-2012, 02:38 PM
Thanks guys
Old 11-21-2012, 07:26 AM
4mm socket but only found one adjuster. How do you bring it in towards center ? My lights shine outward and I drive down a black hole.
