how much lift requires track bar modifications? - Ford Powerstroke Diesel Forum
Old 09-23-2012, 06:14 AM
1.how much lift on the front end ca i go before i need a trac bar modifications? Ive seen 2'' levelking kits that do and dont come with a longer trac bar or a drop bracket.
IM fureing they all must because the axle is being moved away from the frame which requires a longer track bar.
2. do these mini-pack leveling kits work on none OEM leafs? I have "standers" brand aftermarket front leafs in the truck currently, seem to look stock.
3. I was given a set or nice Eagle 10'' rims, with some junk 305/75/r16 tires on them. As i only want to clear 33's with the truck levelled out, was would be a proper size for the rim? Ive heard 285 but i think they would be too narrow for 10'' rim and the 305's seem to suit the rim better.
Thanks, ive searched a ton and came up with pieces but no straight answers.
Old 09-23-2012, 09:01 AM
Go with the 305's on tire size. I would not alter the steering or track bar on a level kit unless handling is adversely affected.
Realistically, you want your track (or panhard) to be in line with your drag link AND you want your front axle to be centered left to right.
If you are not going to 1. install a dropped pitman arm or 2. install high steer, then I would not install a dropped track bar.
If you install a dropped pitman arm, then install a bracket that drops the track bar from the frame and moves it inward to keep the axle centered.
With high steer, I would move the track bar up on the axle to keep it inline with the draglink. This is to avoid bump steer.
On the mini spring packs, if your aftermarket springs are stock replacements from the after market, they should work fine.
This is, of course, only my opinion.
Dan
Old 09-23-2012, 01:55 PM
i'm now leaning towards a leveling kit that includes new complete front leafs and trac bar reloation bracket but its 2/3 the price of a complete 4'' kit.
Old 09-23-2012, 05:14 PM
I've been considering an adjustible track bar, not sure what type of lift up front I have (not mini spring packs, but it is around 3" higher than stock) but 295/70/18s clear everything except the leafs on the right side when turning right
Old 10-13-2012, 06:41 AM
after a little washing i found out i have repalcement factory hieght "standens" brand front springs, yet all the add a leaf leveling kits clearly state that they only work with factory springs.
im thinking they should work with an add a leaf because they should just be factory copies but im going to call my suspension shiop and see what they say.
Im looking for a 3'' leveling kit with a new front lift springs and a quality front trac bar setup.
I just scored 285/75/r16 yokaham geolanders at/s for $400 new
