Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Exterior Discussion
Old 10-15-2007, 04:58 AM
seanoboyle seanoboyle is offline
Door lock actuator
The passenger front door lock has stopped working. I understand this is a problem with the Ford trucks. I have a new actuator from Ford, I took off the door panel this weekend and spent the better part of the day trying to replace the acutator. Does anyone know how to get the old part out? Do I have to remove the window channel and lock assembly completely, or is there some trick I am missing?
Thanks.
Old 10-15-2007, 07:31 AM
Blue01F250 Blue01F250 is offline
Tournaments Won: 1
try this -- may help you..
Door Lock actuators
I hope otherwise I have no idea how to do it as all 4 of mine were done before we bought the truck
Old 10-15-2007, 07:35 AM
Clay Henry Clay Henry is offline
Sooner Powerstroker Mod
Yes, you have to remove the latch mechanism completely, get it out and then the actualtor comes off easily. Its kinda tricky to get it out and back in. Mine came apart slow but went back together pretty fast.
