Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Exterior Discussion
Old 10-10-2007, 08:55 PM
Hooky Hooky is offline
Headlight Mods
Hey Guys:
I just registered on this forum. I am amember on a similar forum for the Duramax Chevys. My question is I have a 2002, 7.3, F-250 and I would like to modify the headlights to where both high and low beams are working together when the lights are on the high beam setting. That mod with the Chevy involved jumping across some circuit breakers under the hood with a small diode. Any ideas if that can be done with the Ford????
Thanks.
Old 10-10-2007, 09:43 PM
ABOBB ABOBB is offline
Is it even worth it???
Welcome to Powerstroke.org
I'm sure there is a way to do what you want to do.. I've just never read about it. Hopefully someone here will know how to accomplish this.
Old 10-11-2007, 04:28 AM
Blue01F250 Blue01F250 is offline
Tournaments Won: 1
Hrmm -- First -- Welcome to the .org!
I'm too have not heard of this mod -- do the Chebby's have two bulbs? or just one like the Fords? We're still trying to figure out how to get the fog lights on with the high beams or parking lamps on the 01 and earlier models of trucks
Old 10-11-2007, 05:37 AM
JoeyCleland JoeyCleland is offline
Send a message via MSN to JoeyCleland
I think they sell a module called a brightbox that does this. Dont know where to get it or how much.
Joey
Old 10-11-2007, 06:38 AM
Logan Logan is offline
The Fat Mod
yup, the bright box will do it. I think they are pretty cheap too. to the ORG.
Old 10-11-2007, 06:56 AM
Tournaments Won: 1
but don't ya have to splice with the bright box and all that too??? I need to read up more on that box..
Old 10-11-2007, 07:13 AM
Bart_3500 Bart_3500 is offline
Electrical Accessories-Dodge Cummins and Ford Power Stroke Diesel Truck Accessories - Geno's Garage
Geno's garage has the brite box for Fords. The price range is between $90 and $125. depending on your year. Geno's has Ford and Dodge stuff.
Old 10-11-2007, 07:21 AM
Tournaments Won: 1
Geesh - $125 !!!
and more info in its description would be nice -- like how do you work it and such other than just plugging it in ....
Old 10-11-2007, 10:42 AM
gcop gcop is offline
PIPE HITTER
You could take a 12 volt relay and do this:
Term 87 to 12 volts constant
Term 85 to ground
Term 86 to the high beam wire on your harness
30 to the low beam wire on your harness
you can use one relay to do both sides, just split the connection from term 30 into each low beam wire on either harness, you will need to use 12AWG-14AWG to be safe. Relay wire and time should be about $5.00 and 20 mins.
Old 10-11-2007, 10:46 AM
Tournaments Won: 1
I'm gonna have to be calling you to do that
I'm a no wiring fool -- or maybe if there is a DFW meet or something where you guys can make it I definately have this thread saved!
