08 mirrors - Ford Powerstroke Diesel Forum
Old 07-10-2012, 10:54 AM
08 mirrors
Considering upgrading tow miirrors , need advice on where to but, I have seen people posting plug and play? Do they come with instructions how to wire in the heaters and turn signals?
Thanks in advance
Old 07-10-2012, 01:46 PM
Dfuser.com has a retrofit kit for 99-03, if u need'em that bad$$
Old 07-10-2012, 03:18 PM
I saw some on ebay for like $500 a set the signal light is white though. Does anyone have experience with these?
Old 07-14-2012, 10:48 AM
You will have to grind off a small locating nub type thing on the part of the mirror that is against the door, other than that everything lines up and direct plug in.
Old 07-14-2012, 10:53 AM
I got some that are aftermarket w/o power extend and fold.
Old 07-14-2012, 12:44 PM
There are a number of guys on the forums that have done this. There is an eBay seller with lots of the power fold power extend which have the connector ends cut off. These are NEW OEM not someone's scratch-and-dent ones for less then $500 for a PAIR.
NEW 2011 Ford F-Series Power/Heated Trailer Tow Mirrors - Left & Right Included | eBay
'08 Mirror install
More '08 Install
Relay
Old 07-14-2012, 12:49 PM
I did a set on my 04 X, if you decide to go thru with it PM me and I will send you the details
Old 07-15-2012, 08:21 AM
Can the the switches be installed on my 03 for all of the controls? Power fold and extend?
Old 07-15-2012, 09:12 AM
It looks as if you would either have to swap your door panels to the 2008 style or modify the door panel you have now. The new switch is completely different than the older style.
Old 07-15-2012, 09:26 AM
Haven't even started putting mine if just have a bunch of links to study. I've read that there's a way to fix the reverse action with a relay. Also, that you can buy the door wiring harness to make things easier.
Here's another guys post.
2008 mirrors - Here's a quick run down of the 08 mirrors to 06 mirrors wire color conversion schematic if you cannot open the pdf version of the document posted earlier in this thread.
P/N 3U2Z-14S411-DLA *see also WPT-219* <--- switch wiring/plug harness
Driver's side:
08 mirror 06 mirror
-Red w/ Silver tracer -Red
-Yellow w/ Silver tracer -Yellow
-Blue w/ Silver tracer -Blue
-Mint Green -Green
-Black -Black
-Black w/ White tracer -Black w/ White tracer OR Green w/ Purple tracer
-Brown -Brown
Passenger's Side:
08 mirror 06 mirror
-Green w/ Silver tracer -Green
-Purple w/ Silver tracer -Purple
-White -White OR White w/ Blue tracer
-Black -Black
-Brown -Brown
** Wire colors for Power-Fold & Power Telescoping functions were already posted earlier in this thread.
Here's the link I used for the relays in order to get the 08 mirrors to reverse the operation of the left/right functions and operate properly. It might look sort of confusing, but it was really simple to do.
Wiring fix
As far as the switch wiring(mine already had 7 wires uand fit into the 08 mirror switch). I just added the 8th wire that I took out of the WPT219 that I ordered.
If you flip the switch upside down so that you are looking at where the connector plugs into i will base my colors like this...
1234
5678
1-Black
2-purple
3-orange/green stripe
4-black wire I added
5-blue
6-yellow
7-green
8-red
Here is how I hooked up the wiring coming from the 08 mirrors to the stock wiring coming from the door.
08 mirror.......................................OEM
_______________________________________
Driver side
mint green----------------green/white stripe
black/white stripe---------green/purple stripe
black---------------------black
yellow--------------------yellow
blue/silver dots------------blue
red-----------------------red
brown--------------------brown
Passenger side
yellow-------------------yellow
white--------------------white/blue stripe
black--------------------black
purple/silver dots---------purple/brown stripe
green/silver dots---------green
black/white stripe--------green/purple stripe
brown-------------------brown
