New Rims - Ford Powerstroke Diesel Forum
Old 07-01-2012, 05:25 PM
Winning DUHHH
New Rims
Hey guys, I came across a new set of rims. For the deal I got on them I couldnt turn it down.
I assume these are lug centric rims, and I need to get a set of Lug nuts for the rig. Any idea on the size/pitch or lug nuts I need?
Ill attach a few pics.
Old 07-02-2012, 07:10 PM
Winning DUHHH
bump....TTT, anyone?
Old 07-02-2012, 08:18 PM
I'm assuming you meant hub centric. But if you go to any tire store they can get you the right lug nuts. Most have them in stock along with keys. At least Tire Rama up here did
Sent from my iPhone
Old 07-02-2012, 08:41 PM
Winning DUHHH
Well, isnt there Hub centric and Lug centric.
My stock rims are centered by the hub, with a flat ended lug nut. Thus being centered by the Hub.
These need a tapered lug, on the stud. Wouldnt these be considered lug centric because the lug nuts are centering the rum on the studs?
Correct me if im wrong, I probably am!
Old 07-02-2012, 09:08 PM
Well I guess I'm not really sure then. I thought all our trucks needed hub centric wheels, but my lugs are the tapered ones too. Anyways a tire store will typically have the right ones in stock. I don't have the specs on the lugs though.
Sent from my iPhone
Old 07-02-2012, 09:10 PM
Winning DUHHH
Ok thanks,
Id really rather find the pitch and thread to order them through one of my suppliers then get bent over at the tire shop.
Old 07-03-2012, 01:05 PM
If my '01 is the same as the '99 you want 14MMX2.00
Old 07-08-2012, 02:47 PM
Winning DUHHH
Yessir thank you. Here's how it looks
