going from 6' lift up to a 10.5 , and need help - Ford Powerstroke Diesel Forum
Old 05-13-2012, 04:14 PM
i have a 2001 f250 with a 6inch lift on it now all spring in front and has blocks in the rear with extra leafs , i wanna go up to 10.5 " what all do i need to do ? i was looking at the icon 4.5 hanger/shackle drop for the front, i plan on raising the rear only 2 inches would i need to do any other mods in the rear ? i want the truck to ride front high
going from 6' lift up to a 10.5 , and need help-552833_2978293812219_1108090119_32341599_1564483693_n.jpg
Old 05-14-2012, 04:42 PM
You will need x over steering and an adjustable trac bar for the front along with longer shocks. You might need to lengthen the front drive shaft and/or clock your transfer case. For the rear you can measure your existing block and contact precision metal fab and order blocks 2" longer than what you have. They make nice ones that capture the u bolts. Longer shocks and maybe traction bars depending on how those blocks work out. Dont stack blocks, its a bad deal. Its very expensive going over 8" of lift when done correctly. If you have the money you could just order a Icon 10.5" kit, install it, then sell your 6" to get some of your money back.
Old 05-15-2012, 01:10 PM
i was almost thinking bout buying just a new kit and doin exactly that the 10.5' and 12.5' price diff aint nothin either may as well go higher lol
Old 05-15-2012, 11:40 PM
Sounds good. Make sure to post pictures when its done. I'm going with 10.5" and 38's after I get mine repainted with a 05-07 front end.
Old 05-16-2012, 08:49 AM
yea deffinatley , it will be sickkk
Old 05-20-2012, 06:20 AM
you don't HAVE to do Crossover at the time of 10.5 you'll be fine without it at that time. 10-11" is the grey area for needing it or not, but I've run all mine without crossover at 10 and it was fine, I run crossover on this one but remember if you do decide to do crossover don't forget the remote track bar mount to get the angles back in spec!
you could order all PMF parts and get his traction blocks, I run 8" springs, 7" blocks and no traction bars and have ALOT of axle wrap so I recommend traction bars with anything over a 5" block.
Chad
