| 99-03 7.3L Exterior Discussion Body and Accessories Talk |
wheels
what size wheel and tire can i run on an 01 srw 2wd i just want stock ford rims i was wondering if i could run the 08 rims would it work or not
yes they will but you will need wheel spacers for 05-2012 rims to fit 99-04 trucks
What size and for the front or back
Both, they will need to be 2 inch. It is 1 7/8 but u will find 2 inch spacers
I was told that I just needed 2" spacers on the front not the back because of the offset of the new wheels were 1 7/8 off right
yeah correct, but if u look now with the original wheels, Then picture fronts sticking out 2 more inches? Naturally, to look even, you spacer out the back too. The fronts need the sacers to not rub the leafs, The rears are needed so tires will all stick out the same amount
My truck don't have leafs it's 2wd and I'm doing the conversion from a dually to a single if that matters at all
ok, dually rear is wider. So you wont want the spacers on the back
