can i add a leveking kit to a 4 inch lift? - Ford Powerstroke Diesel Forum
Old 03-10-2012, 01:31 PM
I have a 4 inch lift and i want to add a little bit more height to the front. If i added a leveling kit to the front would i need a 6 inch lift trac bar bracket and extended brake lines? I have a 2 inch leveling kit from the truck since thats what i had on before the lift. so i was just gonna pull the spring pack apart and add them into the buch where ever they fit.
Old 03-22-2012, 09:23 PM
probably not the best idea.. you would be better off with six inch springs. Your lift springs are arched different than the stock springs and it sounds like you have an add a leaf which was meant to work with factory springs...
are you over on lawn site?? I know your name from somewhere
Old 03-23-2012, 03:26 AM
Yeah. I'm on plowsite and lawn site haha
