Removing door panel..??? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 03-04-2012, 09:00 AM Thread Starter
'99 350 CC, trying to replace my mirror and need to remove door panel to unhook wiring to mirror. Found screw behind light in door, found screw next to handle when I removed the window switch panel. What am I missing?
THX
12/98 E-99 CC Long Box 4WD Dually Lariat, Banks IC/Wastegate/6-Gun........Heated/Cooled Cupholders
Degnol is offline
post #2 of 4 Old 03-04-2012, 09:09 AM
7.3550Duty's Avatar
You need to pop the window switch up and remove the screw behind that and then you just lift with the handle and the bottom of the door up and it will take some persuading with it but it should come off right after that.
Robert
01 F350 CCSB
a few mods
7.3550Duty is offline
post #3 of 4 Old 03-04-2012, 09:14 AM
yep, you got it. only two screws, then grab the handle and lift UP. yep, its that easy...
2013 F250 CC/SWB Lariat FX4
325/60/20 Nitto Terra Grapplers
NOBAMA!!
Is it just me, or does it seem like all Dodge drivers are A$$holes?
jdalhaus is offline
post #4 of 4 Old 03-04-2012, 10:27 AM Thread Starter
Thanks for all the help. My problem was a speaker enclosure with a couple of screws that went into the door. Sheesh, I love aftermarket engineering!
Degnol is offline
