SEMI TIRE CONVERSION :) - Ford Powerstroke Diesel Forum
Old 02-01-2012, 07:29 PM
Would i be able to use the American Force Beast SS 19.5 rims on my reg cab long box without a lift? and does anyone have these?? how do you guys think they would look on my truck?? any input would be great
Old 02-03-2012, 07:27 AM
I believe you'll need a leveling kit at least.. haven't seen a f350 runnin' alcoas without one.. but that doesn't mean its not out there. It's all just going to be a matter of the size of tire and backspacing of the wheels, but you have to keep in mind your going from stock to an almost 20" wheel and close to 35" (ish) tire.. Good luck though, haven't seen a f250 with semi tires, i'm curious how it'll look..
Old 02-03-2012, 07:52 AM
There was a great thread about this subject somewhere on this site. You should try to find it. I'll look for it too.
Old 02-03-2012, 08:18 AM
its very effing expensive
Old 02-03-2012, 10:55 AM
Is your truck 4x4 or 2wd. You should be able to fit 245 on your truck the way it is now. 225 are smaller than your current tire only 32" diameter. I have the same configuration truck and am looking at a place near me that sells 19.5s The only thing I can say is that the offset may cause rubbing on the inner fender. My old service truck was on 22.5 and 235 tires and it rubbed at full lock sometimes so I welded a steering limiter on the axle.
Old 02-03-2012, 10:56 AM
couple pics from ricksons website
Uploaded with ImageShack.us
Old 02-05-2012, 06:36 PM
thats the exact setup i want right there. i love this rims.
Old 02-05-2012, 07:01 PM
Where do you find semi wheels for a srw truck. I wiould love to do a set on my truck but i only find them for drw trucks
Old 02-05-2012, 07:21 PM
Rickson and vision make direct bolt on 19.5's for srw trucks. I think eagle alloy might have one also
Old 02-05-2012, 10:57 PM
I have 22" with 305/45 tires (about 32.7 inches) on a stock height F250 2WD. No leveling kit or anything.
