Will 2011 bed fit a 99?? - Ford Powerstroke Diesel Forum
Old 02-01-2012, 11:53 AM
Anyone know if a 2011 bed will fit a 1999?
Thanks
Old 02-01-2012, 03:03 PM
It will fit fine, but it won't look quite right because the bodyline around the wheelwell and lower side panel has changed a little bit.
So it just depends on if you want it looking perfect or not on your 99.
Old 02-01-2012, 03:26 PM
Ya the bodylines wont line up
Old 02-02-2012, 05:47 AM
Its only going to cost me 300 so I think I will take the chance and if it does look right and is way off then I might do something else.Thanks for the input.
Old 02-26-2012, 06:51 AM
Hey Matthew,
Do you have photos of the bed mounted on your truck? I found a 2011 bed and want to put it on my 2002!
Mike
Old 02-26-2012, 07:15 AM
For 300 bucks I'd do it.
Old 02-26-2012, 07:45 AM
Feedback Score: 3 reviews
Body lines match just the shape of the rear wheel well is slightly different and stands out more
Old 02-26-2012, 08:03 AM
I managed to find some photos and compare and yes it looks like the rear fender body line is much larger than the 02 front fender lines. I guess I'll keep searching for a bed. To match the body lines I should be OK up till 2007??
Old 02-26-2012, 02:18 PM
The beds are the same up to 2010.
Only the tailgates changed for 2008, but they will still work.
Old 02-28-2012, 12:08 AM
Try these guys.... Home Page
